Question about Vehicle Parts & Accessories
Have a problem with bursting clutch master cylinder for toyota qauntum d4d 2.5
    Scholar:
    New Friend:
  • 95 Answers
Check to see if its covered under warranty or a recall first and makes sure the level of the fluid isn't too high. leading to excessive pressure.
Posted on Nov 17, 2015
Got a 1.9 dci megane 2006 clutch pedal just went to floor could it b burst pipe
Hello William Horne,
Burst HOSE...
or blown cylinder seal ... master or slave
(My opinion...replace those in PAIRS).
A look into the clutch cylinder area will show
(quite an obvious leak)...
Hope this helps
Carnac the Magnificent
Nov 24, 2017 | Cars & Trucks
Where is the clutch fluid located on Toyota hiace 1998 ?
Under the hood, on the firewall, there is the clutch master cylinder with a reservoir on it. This is where the fluid goes. Uses brake fluid, just like the brake master cylinder, also on the firewall. The clutch master only has one line coming from it-the line that goes to the clutch slave cylinder.
Aug 02, 2017 | Toyota Cars & Trucks
Gear
Master/Slave cylinder issues, check fluid levels of brake fluid reservoir and bleed system where it attaches to the transmission.
Have someone push on the clutch pedal as you watch for movement of the clutch fork where the Slave cylinder attaches to the transmission. If the Fork moves then it is either bent or slipped off the throw-out bearing, the throw-out bearing is seized maybe, the clutch disk itself could be worn or the syncro-mesh teeth inside the transmission are worn from missing gears while shifting.
Apr 21, 2014 | 2005 Toyota Corolla Verso
Clutch slipping on toyota previa d4d 53 plate can it be tightened or will it need replacing
The first thing to check is the clutch release mechanism for faults. If a cable check that the clutch operates fully from dis-engaged to engaged as if the pressure plate is held 1/2 off then the clutch will slip. If hydraulic the same fault will be from a master cylinder that has a blockage in the compensating port. It is cheaper to fix the operating bits before pulling out the gear box because normally if a clutch is worn out or the pressure plate is broken you will go nowhere regardless.
Dec 11, 2013 | Toyota Previa Cars & Trucks
How to change a clutch master cylinder on a 2006 toyota tacoma
remove line from the side of clutch master cylinder two bolts or nuts on firewall inside vehicle is a pin on the upper side of clutch remove and pull old unit out bench bleed new master by filling and pressing in on the piston of the master cylinder. if you dont have a hose fitting dont bench bleed bleed it in vehicle( this method takes longer) install back in vehicle and hook it all back up torque bolts to 25 ft lbs then bleed the slve cylinder from under vehicle near back of motor just like bleeding brakes pump up hold and release the line pressure by opening valve on slave cylinder.
Apr 06, 2013 | 2006 Toyota Tacoma
I have a 1992 chevy pickup and the manual clutch will not engage. The clutch pedal goes to the floor, and will come back up. The clutch assembly only has about 15000 miles on it.
not sure on that model if it is cabel check conectoins posible broken cable,,but i think it was hydrolic ,causes could master cylinder on firewall internal leak check fluid can leak inside under dash,also check slave cylinder for leak or burst,leaking hose or pipe,but first check fluit level on top of master cylinder
Aug 06, 2011 | 1983 Nissan King Cab
Hydraulic Clutch Problem in an 82 Toyota Pickup
If you are leaking fluid from the clutch master cylinder then you have air in the system. You could try and bleed the air out of the clutch slave cylinder to get the gears but it would not last. The only way is to replace the defective master cylinder, replace all of the fluid and bleed out the air through the slave cylinder.
Apr 07, 2009 | 1985 Toyota Corolla 2 Door
MR2 after 2 mins of starting the smt light comes on.
it sounds like the clutch actuator is worn out.
The clutch actuator has 2 parts:
1. the clutch master cylinder
2. the clutch slave cylinder.
Try to replace the slave cylinder first, and if it is still not solving the problem, then try to replace the clutch master cylinder
Good Luck
Feb 06, 2009 | 2003 Toyota MR2 Spyder
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
