Whirlpool AWG500 front loader washing machine Rust inside the casing and drum making a grinding sound when turning. Also not spinning properly and leaking underneath
Suggested part replacement please
  • 101 Answers
Main Bearings & seal are shot, this is a big job & usually attempted by a serviceman only.
Posted on Apr 08, 2015
SOURCE: GE Front loader washing machine
renew your door seal
Posted on May 27, 2007
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
Loud grinding noise when on when it starts to spin?
If it is a front loader, then it sounds like the drum bearings have failed, spin the drum from the front by hand, if it feels rough or is noisy, then bearings have failed.
Jan 26, 2011 | Washing Machines
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer Loud Grinding sound in spin cycle
HI,YOU MIGHT HAVE EITHER A BROKEN SPIDER THAT IS LOCATED BETWEEN THE IN AND OUTER DRUM OR A BROKEN BEARIG.BEST YOU GET A EXPERT TO HAVE A LOOK AT IT FOR YOU.GOODLUCK.MOHAMED
Sep 10, 2008 | Washing Machines
FAULTY WASHING MACHINE
is it a GE or Hotpoint? if so it is the main bearing. the center seal might have leaked water on the bearing.  if you look inside the washer you will see a ring of rust splatter inside the case of the washer. if this is the case than you have to change the transmission or buy a new machine.
transmissions are $200+
Jun 27, 2008 | Indesit Washing Machines
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loader drum grinding
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimeter or two, it is probably worn bearings. Regarding the bad smell - Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Sep 14, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
