Question about Eton Audio Players & Recorders
Is it possible to change or reset weather channel frequency on FR360 eton solarlink
2 Suggested Answers
hmerchant110
  • 7191 Answers
SOURCE: eton solarlink FR360 operation manual
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Sep 08, 2011
Hi, I got my sister a Eton solarlink FR360 for a present a few months ago and now the sound/volume doesn't work? Can this be fixed? I can't find the receipts otherwise I would take it back.
you should probably go to the store were you bought it and see what is the matter and I don't know what this is but see what they can do and if they cant fix it then you might either have to go without sound or get another one
Mar 25, 2014 | Eton SolarLink FR360 AMFMWeather Radio
Iphone won't charge from eton solarlink
could it be that it isn't a charger not supplying enough voltage
Mar 25, 2013 | Eton FR370 Solarlink Radio Red
Freq displat out on Eton sat 750 on airband
It should not be very significant. The gap between two neighboring channels in AM/SW can, on some radios, be set to 9 kHz or 10 kHz depending on countries. For FM the separation is about 100 kHz or 0.1 MHz. Set the right frequency then use the Lock feature. It will prevent any shift/drift of frequency ( and any other changes) until you unlock.
Dec 09, 2012 | Eton Satellit 750 AMFMSW Radio
How do you program your local weather county codes?
This radio doesn't have the facility to be programmed for your local weather county code.
When set to alert it will pickup on the strongest alert signal in your area.
May 05, 2011 | Eton Solarlink FR600 AMFMWeatherSW Radio
How do I set my Eton Fr400 to get weather alert? Does it need to be on a particular station? Should it be turned on?
Free PDF Manual at the link below detailing how to setup.
http://www.etoncorp.com/upload/contents/307/FR400_Manual_0107.pdf
Please post State, County & ZIP is you need any assistance with your weather station frequency.
Please leave feedback.
Cheers
Andy
Apr 28, 2011 | Eton FR400 Radio
Resetting an eton fr-360 weather radio. it will not come on even with new batteries. how do i reset it.
I had the same problem so I sent an email to Eton's customer service, this was their response and it worked for me:
Please use the following procedure to reset it. Please remove your AAA batteries and unplug the rechargeable battery. Let the radio sit for 30 to 45 minutes, then put them back in. To play it from the AAAs press and release BATT first, then POWER. To play if from the rechargeable, first press DYN/SOL, then turn the crank for 90 seconds, then press and release POWER.
To charge the unit with an AC adapter, plug in the AC adapter, press the DYN/SOL button and make sure that it reads SOL/DYN in the lower right corner of the display. Let it charge for about 8 hours. Make sure that it still says SOL/DYN and press the POWER button. It should play for about 5 to 6 hours, depending on the volume.
Apr 27, 2011 | Eton SolarLink FR360 AMFMWeather Radio
How do i program my eton fr 800 radio to come on automatically. Thank you.
  • To get your alert radio to come on when there is a weather alert first you needed to find the right NOAH frequency to turn on automatically to.
  1. Extend the antenna fully.
  2. Turn on the radio.
  3. .Press the "WB" button at the top of the radio.
  4. Turn up the volume and press the ^ or v button to cycle through all 7 of the weather channels.
  5. WB and CH will appear at the top of the display., with 1-7 next to CH.
  6. Select the strongest channel you can hear (if you can hear more than one channel. Usually only one channel is heard).
  7. The strongest one is the broadcast from your area.
  8. Now adjust the volume you want the radio to turn on in the event of an emergency.
  • Now once you have the weather frequency set for the radio to turn on to, we need to make it able come turn on in an emergency.
  1. Press the ALERT/WB button at the top of the radio.
  2. The alert light shines in the upper left corner of the radio.
  3. The audio will disappear but the radio is still on.
  4. It will monitor Noah until an emergency occurs and at that point a siren or a voice will alert you. Then you press the WB button to hear the alert.
Regards, Tony
Apr 27, 2011 | Audio Players & Recorders
I did not get a manaul for the Eton FR360. How do I get one?
Mar 26, 2011 | Eton SolarLink FR360 AMFMWeather Radio
How to get the Ross County, Ohio code
Go to http://www.nws.noaa.gov/nwr/indexnw.htm#sametable and click on Ohio then find Ross County. The code is 039141 out of two NWR transmitters in Chillicothe and Otway. (The website to obtain this info was printed in the owners manual. ;) )
Oct 29, 2010 | Eton Solarlink FR600 AMFMWeatherSW Radio
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Jun 15, 2008 | Radio Shack Pro-82 Scanner
150 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
David Burbee
David Burbee
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
