Question about Cell Phones
How to unlock maxis pin lock - Cell Phones
Back door on vw maxi caddy 2010 wont open, all other doors working, any ideas
The motor may be moving, but the attached arm to the actuator could be broken, fell off, etc. You will need to open remove the door panel to see exactly whats going on.
Mar 02, 2015 | 2010 Volkswagen Caddy Maxi
How do unlock PIN number
Do you want unlock network lock pin number? What is your mobile brand name &model? If you need network unlock pin you can visit this site Theunlockspot.com here you can get the network unlock pin number and unlock your mobile easily. To get the code you have to mentioned your mobile brand name,model,which country is locked now,network provider and imei number. Then they send unlock code through email.
TheUnlockspot.com
Feb 23, 2015 | Cell Phones
My imei no is 353561050606221 sony xperia st25i. want to know sim unlock pin, cannot remeber old pin.
Sim unlock pin differs from security lock pin . sim unlock pin indicates that your Sony Xperia St25i is locked with your present carrier . To unlock it, use unlock code . You can get it from any of the online vendors like ClassicUnlocking.com to unlock it . If you want to break security pin from your Sony , use default codes .
Jan 07, 2015 | Sony Xperia U ST25i Smartphone Black...
Similar network lock need pin for my Samsung phone imei # 351863040074920/05
Do you want to remove the Samsung Network Lock from the phone?
You can use unlock code to unlock it.Visit the site Wickedunlock.com get unlock code at reasonable cost and unlock from service provider lock easily.There is no more network lock pin.Only network unlock pin available.
Aug 01, 2013 | Cell Phones
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Jan 09, 2013 | Remote Starter with Keyless Entry
Kids entered wrong pin too many times. Sim Now Blocked. Can you provide Puk to unlock the sim
Hello 76wild,
There are many type of provider,
For my provider,(maxis), i'm need to dial *100# to get the menu from maxis,
Then I will replay number 9 foraccount information
After that it will display menu again.
And here I;m replay choose number 6 for PUK code.
After that, it will ask your number that you want PUK.
replay phone number.ex 0129992222
Then it will give the puk, then insert that puk and give the new pin code.
I'm just give you example from my provider only.
Jul 24, 2011 | Cell Phones
My phone is seeing sim lock
There are two types of Sim Lock,One is Network Sim lock,another is Sim Pin lock ,Sim Pin lock can be Unlocked using the default code get from service provider....To get the Network Unlock code reach here
Unlocking4free and Unlock it...
Jun 01, 2011 | Health & Beauty
How do you master reset a gravity touch
If your Samsung Gravity T (T669) is stuck on the PIN lock screen and you do not have the code to unlock, you can try a master unlock code... 73683139 to override and then go to settings and turn off lock feature. When you reactivate lock feature it will prompt you to select a new PIN.
If your phone requires the T-mobile PUK code to unlock (you get a message that says call support PIN is locked) the PUK unlock for this phone is **05*22998214*0000*0000#. This will unlock device and reset PIN to 0000.
Enjoy.
Jan 24, 2011 | Samsung Gravity Touch T669
Unlock the PIN - Blackberry 8820
yes it needs to be unlocked before using it for other networks, try codes from http://www.unlocking4u.com/
Jan 04, 2010 | RIM BlackBerry 8820 Smartphone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
