Question about Health & Beauty
White round markings k11 - Health & Beauty
I have an Acer K11 projector and there are a whole lot of white spots on the bottom right of the screen that looks like dust on the lens but it is not as I have cleaned the lens . Any advice ?
This is a DLP projector, the white spots are likely bad pixels and the DMD chip will need to be replaced. Will run you around $150 or so.
Sep 22, 2016 | Acer K11 Projector
Wire up towbar 1998 micra k11
Hi follow these instructions for seven pin plug. If they dont suit you can find more help through google. Yellow= L/H Flasher. Green=R/H Flasher. Black= L/H Tail Lamp. Brown= R/H Tail Lamp. Red= Stop Lamp. Blue= Fog Lamp. White= Earth. With a power tester find each circut and join each color wire in.
Feb 28, 2015 | Cars & Trucks
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
Central locking playing up on nissan micra k11
You probably have a defective door lock switch. (the one on the inside door panel)
May 14, 2012 | Cars & Trucks
Timing of vw engine
You'll need a timing light connected to the number on spark plug wire. On the top of the transmission, below the cylinder head, you should see a round plug, (usually green) with a clear plug in it. Remove the plug, you can then see the flywheel, there will be marks on the flywheel to set the timing. Mark the timing mark with white paint, start the engine, shine the light onto the marks, to adjust, loosen the distributor to turn back or forth to adjust the timing marks.
Feb 26, 2010 | 1992 Volkswagen Jetta
I have nissan micra K11 with light flasing code
From what I understand it is the Nissan Anti-theft System (NATS) correct ?
The other numbers you show do not correspond to any codes I can find.
The reason the car is not starting is because the Nissan keys MUST be programmed for that car.
Make sure you did not have a new key made and that if you did you have to program it.
Your owners manual will tell you how.
Please elt me know what you find.
Feb 08, 2010 | Nissan Micra Cars & Trucks
Health & Beauty Logo
107 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
