Question about ASUS A6Ne Notebook
Computers motherboard is the red light is burning , but my computer does not work is my computer model asua Vento 7700
    Problem Solver:
  • 13 Answers
Your motherboard is fried. Replace it.
Posted on Sep 11, 2017
2 Suggested Answers
SOURCE: asua 945 motherboard not power on
check whether the RAM is inserted properly and once you change the CMOS battery and trying it powering on ...
if you still persist the same problem then check whether you are getting the power supply for the RAM slots or not ..
if you are not getting the power supply for the RAM slots then there may be problem in voltage regulator or in the transistor after replacing that your problem will be solved ..
you can do the above if you are an experienced professional , if you have no idea about that then i recommend you to take your motherboard to nearest motherboard technician ...
regards
-Dileep
Posted on Nov 23, 2008
Is it a computer that controls the stoplights so you can drive to work?
Yes, computers are everywhere. Some intersections have sensors embedded in the road,
so that when a vehicle rolls over the sensor, a signal is sent to the computer, and the computer
turns the traffic-light from RED to GREEN.
Computers are also used to "synchronize" a series of traffic-lights, usually so that traffic heading "into" the city during the morning rush-hour gets a series of GREEN lights.
Jun 15, 2011 | Computers & Internet
Asua p4v8x-mx .usb drivers cannt work
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 20, 2011 | ASUS Computers & Internet
Where can i find parts for a 2006 Vento motorcycle. I need the tail light because it does not light up whenever i brake. I dont know what model it is because i bought it used from an individual. Its a...
there should be two screws that hold the tail light cover over the bulb (red) take that off and and then just take the bulb with you to a parts store it would most likely be a very common bulb they would have in stock
Feb 26, 2011 | Vento Rebellian Motorcycles
Do you asua driver p5gz-mx motherboard download
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -<br /><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://usa.asus.com/index.aspx"><span style="mso-spacerun: yes"> </span>http://support.asus.com/download/download.aspx?SLanguage=en-us</a></span>
Aug 29, 2010 | ASUS P5GZ-MX Motherboard
One red light light is blinking in my Volkswagen Vento car model-1994. On that light "ABS" is mention. Can u plz tell me wat's that light mean?
It means there is a fault with your ABS System Antilock Braking System ------------------------------------
Jan 25, 2010 | 2001 Volkswagen Golf
Bios update problem
ther is a swich in your computer that tells it if system was opened its just a worning
go into your biose and turn warnings off,
its that simple.
i dont know you biose but i do know this proble.
and also make shure you close up your computer properly so it reds closed in the biose.
hope this helpsa,
daniel.
Dec 29, 2008 | ASUS A7V400-MX Motherboard
Asua 945 motherboard not power on
regards
-Dileep
Nov 23, 2008 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asus vento 3600
Installation and assembly Now it was time to get to grips with the Asus Vento 3600 for real. We fished out a test motherboard and some drives and got to work installing the components into the ASUS case.
The side panel ships secured by a single screw which needs to be removed before you can use the side swivel handle to open the case. Once this was removed, turning the handle clockwise unlatches the side panel, allowing it to be pulled away. The swivel handle operates very smoothly and neatly, and adds immeasurably to the whole space-age feel of the case. The spacious interior allows plenty of room for all ATX motherboards. Thanks to the extra height of the case, the top two 5.25 inch external drive bays are above the plane of the motherboard, so even if you have a full size board, you can mount at least two CD drives without worrying about them interfering with the board.
The backplane of the case sports built-in risers for most ATX motherboards, though additional risers are included if your board needs more or different connections. Installing the motherboard was straightforward as we'd expected
One thing we noticed and appreciated at this point was the way that ASUS had rounded most of the steel edges inside the case. Having worked in computer stores, I appreciate any attempt to protect our tender hands from the pain of sharp steel 'case cuts'.
The expansion slot covers are secured by green plastic locking tabs which need to be levered open and removed from the case. The metal covers can then be easily removed and PCI, AGP or PCI Express cards installed. The tabs can then be returned to their places, locking the expansion cards in place.
Nov 10, 2007 | ASUS VENTO 3600 PC Case - Red (14270)
Computer is not booting
Open the case and try to rester CMOS SETTINGS
Or:
check ram
hdd
and PW ( POWER SUPLY )
Oct 30, 2007 | Gateway 310S (2900621) PC Desktop
ASUS A6Ne Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
