Question about Nortel Computers & Internet
My nortel networks passport1612G, problem booting ok but No data output
  • 6 Answers
It is a long time worked on nortel.
check the cards have inserted properly with the interface.
that would be my first look.
Posted on Apr 15, 2015
Is there a "translation" for Nortel Network serial numbers? Can you tell the Country of Origin from the SN?
Hi
I have found a manual here which gives information regarding key codes and serial numbers on Page 66. It can be downloaded and saved in pdf format from here:
http://data.manualslib.com/pdf2/31/3005/300494-nortel/callpilot.pdf?bc5faed6f2944386bbe43827bb387143
I have not found anything regarding serial numbers and Country of Origin, although I expect that a Nortel engineer would have such a reference, I just can't find it in the public domain - Sorry.
Hope this is of some help even if not as complete as I would prefer, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Nortel Computers & Internet
Nortel 1050 and BSR222 VPN Connection
1.  What you have is a "software settings" in several  locations that require "exact entries".  Without us seeing what  "entries" are being asked by the programs or what data needs to be inserted by the routers at each location, there is no way anyone could possibly solve your problem long distance.
2.  The basic generic information was supplied to you at another website you visited but obviously did not help you.  I appreciate you having the confidence by asking anyone here to guide you but I think you need to have some one physically there to fix the problem.  If someone here knows the answer and can solve this problem by all means jump in.
3. My solution is for you to look in the yellow pages for your town where you live under "networks" or "computer networks".  Some one locally should be able to come out and solve this for you.  VPN networks at this level require a "hands on" solution unfortunately and not a "cook book" answer.  Get one field wrong, you will spend days troubleshooting it.
This is the best solution for your problem in this case.  Anything else would be a great disservice to you.
Oct 23, 2007 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
I have Nortel Networks T7316 and cannot dial out.
Check your cables and make sure everything is plugged in! Also make sure your company doesn't have any restrictions for the number you're trying to call - it can happen sometimes. If everything fails try to consult the user manual.Nortel t7316 pdf manual
Nov 13, 2013 | Nortel Computers & Internet
Need password
You have two choices:
  • if you have console access to the switch, and don't mind losing the config:
    • boot it with a console cable
    • Press CTRL-C when the diags start. It should then show a menu.
    • select the option to clear NVRAM.
    • Save and boot the agent
  • If you have SNMP access:
    • Download the config to a TFTP server
    • Edit the password in the config
    • Update the config via TFTP
Nov 01, 2013 | Nortel Alteon 3408 Content Switch
How do I change the passowrd on a Nortel T7100 if i forgot my other one?
boot with your administrator account, insert in the control panel and check the user account . and change your password. other wise there is a very long process to remove your pass.
Oct 17, 2013 | Nortel Networks T7100 Corded Phone
Need cli entry for factory default reset.. adding old switch from another site to new stack and want it clean on factory defaults
Follow these steps:
  1. Connect to the console port of the switch (9600,8,N,1)
  2. Reboot the switch.
  3. When the first line of the diagnostics tests is displayed, press CTRL-C. The system then displays a menu.
  4. Select option "i" to factory default the switch.
  5. Select option "a" to run the agent code.
Upon boot up, the switch will be in a factory default configuration.
Feb 24, 2011 | Nortel Networks Nortel Ethernet Routing...
How to Assign an IP address in Nortel 1648T switches
Add a computer to your network, and install Microsoft Windows Server on that computer, and enable its "DHCP-server" component. Then, this computer will supply IP-addresses for all the other computers connected to your switch.
The switch is _NOT_ a DHCP-server; therefore, you need to add a DHCP-server.
Dec 10, 2010 | NorStar Nortel PASSPORT 1648T ROUTING...
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel 3120 Secure Router
NetFlow is a network protocol developed by nortel Systems to run on router IOS-enabled equipment for collecting IP traffic information
Jan 30, 2009 | Nortel 3120 Router (SR2102002E5)
Computers & Internet Logo
326 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
