Question about Philips Televison & Video
How to locate the faulty component of my tv philips model 21pt5006/71 because after turning on about 5-10 secs. it will shutdown?
5-10 secs. after turn on it shutdown
    Top Expert:
  • Philips Master
  • 74,136 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Apr 08, 2015
Model 47PFL7422D/37. Why won't it turn on?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 05, 2015 | Philips Televison & Video
Sony kv36xbr800 service code blinks 7times after tv shuts itself off
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 13, 2015 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hi I have 2 faulty LCD TV with A1T4l30PN00 power supply. One of the lcd you turn on the tv with remote control and the red light is bliking but will not turn on the TV. I know the power supply is faulty...
TV is often turned off when some parts of the circuits got too hot. You should try to use a room fan to cool the back of the TV and see if it improves by itself before you try to fix the TV. Overheating is often caused by condensation, which also can be dried by a room fan slowly move the air..
Nov 30, 2010 | Televison & Video
Turn itself off as soon as you turn it on (37MF33ID/37)
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is ON then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
but as you mentioned that the tv turns ON for some seconds then automatically turns off this indicates that the power supply board is not faulty but there is a component on the board that is getting over heated because its got weak so due this overheating of a component the circuit gets short and tv shuts off.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 20, 2010 | Philips 37MF321D 37 in. LCD Television
PHILIIPS 51 IN PROJECTION HD TV
6 slow and 1 fast blink error on this model is vertical sweep failure. vertical ic's are located on large signal board. to verify error is correct would recommend disconnecting 1516 6 pin connector on lsb to msb as sometimes that board causes shutdown issues and if no change reconnect and disconnect crt anode leads going into hv generator and if no change replace large signal board
Aug 22, 2008 | Philips 51PP9200D Television
Hi, we have a phillips tv. it is about 6 orso years old. within the last 6 months, it has starting going off. you turn it on and it may play 5 or 10 or even 30 or more minutes but it keeps going off. the...
I wouldnt use that service man. If your set is shutting down its most likely do to the shutdown circuitry being triggerd by a defective component. I would recomend contacting someone skilled with phillips model televisions, most sets that play and then shutdown usually have a problem with a single component that is triggering shutdown, a skilled repair man will test the various voltages to determine the cause of the shutdown.
Jun 07, 2008 | Philips Televison & Video
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
No dc power for philips 27pt543
there is a known issue in deflection circuit specific to capacitor 2455. normal recommendation is to replace that capacitor and 2 transistors right next to that location 7461 and 7463. symptom was specific to random startup and shutdown issues and components should be replaced before proceeding.
Feb 14, 2008 | Philips 27PT543S 27" TV
Set comes on with e.h.t for 4 sec,then goes off B=142v
The problem you described is a case of the shutdown circuit being activated. This is either due to an overcurrent or overvoltage condition within the circuirty of the TV set. This could be an open or shorted component in the High Voltage section of the TV, or an open or shorted component in the low voltage power supply section of the TV. In any case If I were troubleshooting this TV I would check the Horizontal out put transistor to see if it had shorted or opened at one of its junctions. I would also check to see if any of the voltage regulators had shorted or opened. I would also suggest that you check to see if you see any signs of burnt components (note the section).
If you do not have a background in Electronics, I would suggest that you take the TV to a qualified TV shop for repairs. This is because the work that needs to be done is not sinmple, and serious harm can result if you are not careful.
I wish you well on the repair of your TV.
Thank you,
Shuttle83
Nov 26, 2007 | Televison & Video
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
