Question about Bosch Washing Machines
Eroare F18 dar nu este blocat evacuare apa la filtru nici pe furtun la bosch logiixx 8 care este problema?
  • tom cassidy
    tom cassidy Apr 13, 2015
    Hi drimbau , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Prodigy:
    An expert who has answered 500 questions.
  • Bosch Expert
  • 536 Answers
Se pare ca supapa de admisie a apei este cauza problemei.
Posted on Apr 16, 2015
3 Suggested Answers
SOURCE: Tengo una lavadora Whirlpool modelo LXR7144EQ1 que
tengo una lavadora whirlpool, el problema es que no gira para exprimir, todo lo demás funciona, el motor recibe la señal para la función exprimir, sin embargo la transmisión no funciona.
Posted on Dec 08, 2010
  • 1116 Answers
SOURCE: pe ecran apare F18
What you need to do is take out the filter at the bottom of the machine on the front. Put down a few towels and take it out. Clear out anythings that's stuck in there.
Also look at the back were the filter goes and you will see the impeller X shape. Make sure there's nothing jamming the impeller up. It should ping round in stages.
Once the filter and the impeller is clear refit the filter and check the drain hose and were it drains to. Make sure all this is clear as well.
Then retry the washer and see how it goes from there.
If you have cleaned the drain out and the coin trap has nothing caught in it, the only other thing it could be is a bad drain pump. You will also want to check the drain hoses for any clogs. Make sure the pump is getting voltage and is trying to run before replacing it. Hope this helps.
Posted on Jun 20, 2011
BUNA! SUN MARIUS SI AS DORIDACA SE OPATE PENTRU CANON MP990 EROR 5B00 VA ROG SA MA AJUTATI, SA REZOLVA PROBLEMA
https://www.justanswer.com/printers/79u5u-canon-mp990-printer-displaying-error-5b00-message.html
https://translate.google.com/translate?sl=auto&tl=ro&js=y&prev=_t&hl=en&ie=UTF-8&u=https%3A%2F%2Fwww.justanswer.com%2Fprinters%2F79u5u-canon-mp990-printer-displaying-error-5b00-message.html&edit-text=
Imprimanta mea Canon MP990 afi?eaz? un mesaj de eroare 5B00. & Imprimanta mea Canon MP990 afi?eaz? un mesaj de eroare 5B00 ?i nu mai func?ioneaz? .. imprimanta nu se mi?c? din pozi?ia de andocare. Care este problema ?i o pot rectifica singur?.
Distribui?i aceast? conversa?ie
R?spunsat ?n 15 de minute de:
10/26/2012
Tehnician: Shefin
Shefin , imprimant? ?i echipament de birou. Specialist
Categorie: Imprimante
Clien?i satisf?cu?i: 6,156
Experien??: Lucrul ca specialist de suport tehnic cu un produc?tor mondial de calculatoare.
Verificat
Buna,
Bun venit la Justanswer. Numele meu este Shefin ?i m? bucur s? v? ajut.
?ncerca?i urm?toarele instruc?iuni ?i spune?i-mi rezultatul.
  • Opri?i imprimanta
  • ?ine?i ap?sat butonul STOP (Triunghi ro?u)
  • ?n timp ce ?nc? mai ap?sa?i STOP, ap?sa?i ?i ?ine?i ap?sat pe ON / OFF
  • Elibera?i butonul STOP ?i ap?sa?i din nou (2 robinete rapide). (se apas? butonul ON / OFF)
  • Elibera?i toate butoanele p?n? c?nd vede?i cuv?ntul "inactiv" afi?at pe ecranul imprimantei.
  • Ap?sa?i butonul STOP (5 robinete rapide) ?i apoi de dou? ori rapid pe butonul ON / OFF.
  • Opri?i imprimanta ?i porni?i-o ?n mod normal.
Dac? problema persist?, urma?i instruc?iunile de mai jos.
Exist? o band? sub?ire (de 1/4 "l??ime) de plastic care trece prin l??imea din fa?a ?i dedesubtul curelei de transmisie. Aceasta face parte din codificatorul optic care spune capului de imprimare acolo unde este. linii verticale fine negre pe aceast? band?.?n cazul ?n care banda devine o bucat? de crud pe ea, ve?i ob?ine o eroare ?n timpul secven?ei de start-up.Cur??a?i cu grij? aceast? band? cu un ?esut umed f?r? scame.Aceasta a stabilit, de asemenea, un gol ?n imprimare de func?ionare pe lungime (nu pe pagin? ca un cap ?nfundat).
Dac? problema persist?, ?ncerca?i urm?toarele.
Ultima solu?ie este de a lubrifia piesa care traverseaz? c?ru?a de imprimare. Aplica?i unsoare la o parte din piesa pe care o pute?i atinge f?r? a dezasambla imprimanta ?i freca?i-o de-a lungul p?r?ii inferioare a pistei. Ve?i primi probabil gre?eala la ?nceput, dar p?stra?i deschiderea ?i ?nchiderea imprimantei, astfel ?nc?t carulul s? alunece ?nainte ?i ?napoi ?i sper ?m c? va disp?rea dup? c?teva ?ncerc?ri.
Dac? problema persist? sau ave?i ?ntreb?ri, v? rug?m s? nu ezita?i s? ?ntreba?i . Voi fi fericit s? v? ajut.
V? rug?m s? nu evalua?i r?spunsul meu cu POOR sau BAD. Te rog s?-mi spune?i, astfel ?nc?t s? fiu fericit s? continuu ?i s? fac tot ce pot pentru a v? oferi serviciul pe care ?l c?uta?i.
Dac? r?spunsul a fost de ajutor, v? rug?m s? re?ine?i c? RATE serviciul meu cu 3-5 stele sau o fata Smiley.
Mul?umesc.
SHEFIN
http://www.fixya.com/support/t11113587-error_code_5b00_canon_pixma_mp990
Apr 12, 2018 | Canon Computers & Internet
Salut nu merge abs la opel vectra a 94 poate cineva sa ma ajute
Pai ce arata:ABS aprins pe bord:sensori defecti sau deplasati,mizerie prinsa sub senzor.Daca dai roata(rotile) jos,gasesti senzorul si il tragi afara cu grija sa nu il rupi,verifici daca roata cu caneluri de sub el este curata,il cureti de pilitura si alte resturi,verifici cablul de legatura,il pui la loc impins pana atinge(misti roata sa auzi,dupa asta il tragi 1/2 mm inapoi,sa nu atinga.In cel mai rau caz este placa de control de pe pompa acolo deja nu te descurci singur.La calculator iti poate aparea care senzor se da defect/deplasat dar este relativ.De obicei,daca nimeresti se stinge si beculetul.
Oct 22, 2013 | 2000 Chrysler Grand Voyager
HOW TO USE FEATURES ON MY LGIP-400n phone
For this problem contact the mobile service provider........
Oct 14, 2011 | Cell Phones
Salut! Nu stiu de ce nu se mai vede cand scriu la cineva pe messenger si nu se mai vede nici cand scrie cel cu care vorbesc .!!!nu stiti de ce? Multumesc!
Salut, Este un bug destul de des inatalnit la Y! messenger mai ales pe conexiuni wireless.
Exceptand posibilitatea unui virus iti recomand sa inchizi si sa redeschizi Yahoo messenger, pentru a te reconecta la serverul Yahoo.
Feb 01, 2011 | Yahoo Messenger
Am o problema cu mp3 modelFM 6709 .IL CONECTEZ LA CALCULATOR SI ACESTA NU IL VEDE . AM INSTALAT DRIVERUL MI-A CONVERTIT MUZICA DAR PE MP3 NU IL VEDE CALCULATORUL .CIND IL CONECTEZ LA U.S.B. IMI APARE PE...
Nu neaparat, sigla usb arata ca el detecteaza ca a fost conectat la pc. Conecteaza-l la USB si deschide My Computer - daca e bun ar trebui sa apara acolo ca Removable Media - daca apare desachide-l si vezi ce fisiere ai si daca poti sa adaugi altele. Daca nu se deschide sau nici macar nu apare atunci e defect. Ca sa fii sigur incearca-l in alt pc.
Jan 23, 2011 | Computers & Internet
Salut Am o problema cu id meu de yahoo mail si messenger, nu ma pot conecta la el Imi da o eroare 81003003, folosesc acest id de citiva ani si am nevoie neaparat de contul meu deoarece am date necesare mie...
buna acum vreo doua zile mi s-a blocat contul si nu mai pot folosi adresa de mail si ID de mess
, sori_modovan@yahoo.com la intrebarile nu mai pt raspunde deoarece nu imi amintesc raspunsurile pt ca adresa a fost facuta acum aproximativ 8 ani. va rog frumos sa ma ajutati ca am nevoie de informatiile din adresa. astept raspuns pe adresa moldovansorin17@yahoo.com va multumesc anticipat sorin moldovan
Nov 28, 2010 | Yahoo Mail
Unde este filtru de polen la chrysler voyager din 2000
Salut......la evacuare de aer cald/rece in zona picioarelor........cu volan pe dreapta...e in stanga....si invers....cu volan pe stanga.....are un capac negru pe care il slide...(glisant ). Tragi de filtru in jos...
Pedro
Nov 22, 2010 | 2000 Chrysler Grand Voyager
Va rog sa-mi spuneti de ce nu-mi pot citi mail-urile...am 2 adrese de mail,una nu are nici o problema dar pe cealalta nu pot deschide mail-urile...asta inseamna ca adresa e de vina,nu?dar nu as vrea sa o...
Nu ar fi adresa devina.sunt niste setari din mail care nu sunt facute *** trebuie.Ar fi mai usor sa te ajut daca mi ai da adresa ta de mail sa ma loghez si sa vad ce pot face.apoi tu iti vei schimba parola.
Oct 07, 2010 | Yahoo Mail
Nu pot sa intru pe adresa mea de messenger. ce sa fac?
nu pot sa intru pe adresa mea....imi zice ca adresa nu este corecta si nici parola,,,eu am acesta adresa de 10 ani si am tot folosito,,,dar nu imi aduc aminte de intrebarile ce imi cer cand am facut adresa,,m
Oct 04, 2010 | Yahoo Messenger
Mp3-mpf-1720
Foloseste CD-ul de instalare. Are nevoie de un driver care se gaseste pe acel CD. L-am folosit pe Windows 7 care il recunoaste singur dar pe Windows XP este nevoie de CD-ul livrat odata cu Mp3 player-ul.
Jun 29, 2008 | Daewoo Pinno VX320 Digital Media Player
Washing Machines Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
