Question about Subaru 2011 Forester 2.5 XT Touring
Hissing noise under accelleration 2011 Subaru Forester XT
My Subaru Forester Turbo has developed a hissing noise even under light acceleration. I was told by my mechanic it is the clutch on the aircon pump, just had all this attended to and it still remains obviously not the problem any ideas ?
  • 507 Answers
SOURCE: Loud hissing noise on 02 wrx under acceleration.
exhaust leak,or blocked,squashed exhaust,may be turbo pipes leaking or loose,have to get the obvious looked at first,then get mechanic who knows to look at it,dont cut corners,gets expensive
Posted on Oct 23, 2009
  • 3 Answers
SOURCE: how to replace a 1999 subaru forester non-turbo
please my solutions i am All Data computer Erase.
key.
Posted on Apr 16, 2010
SOURCE: inertmitant low idle after flat battery
Hi there am having same problem with my 2001, did you find anything out. also when I go up a hill it trys to sputter out on me, never on the flats tho.
Posted on Jun 03, 2010
  • 550 Answers
SOURCE: 1999 Subaru Forester has developed a shake when
Auto or 5-speed?
Subarus have CV axles in front and back. And a drive shaft from the center differential of the transmission to the back differential.
Yes, it could be the drive shaft or axle. If you turn the car hard left or right do you hear any noises - usually a 'clicking' sound? This is likely a CV axle in front.
Check the fluid in the transmission (Automatic) (info is in the Owner's Manual) to make sure it's full and/or gear oil in the front differential.
If it's an Automatic transmission, the fluid may need changed - NOT FLUSHED - if it has more than 30K miles since last changed.
GL,
TD
Posted on Sep 10, 2010
TDISLine
  • 1874 Answers
SOURCE: Hi, I have a Forester XT premium 2010 auto turbo,
1. My opinion is to check and replace if necessary the knock sensor, (under warranty of course). (Swap a knock sensor by another good one, and test again the car).
2. This "ticking" sound belongs to the engine at full load, and knock sensor must send this information to the Engine Control Module (ECM), which should decrease the ignition advance in order to eliminate the "ticking" noise!
3. The turbocharger is not the root cause of the problem, because the "ticking" sound still occurs when swapping the turbo!
Posted on Dec 15, 2010
Why does my subaru forester s turbo judders on full steering lock after a run of more than 30 mins?
If the steering wheel is turned to full lock position, the power steering system is being exposed to thousands of PSI for a brief moment until the pressure relief valve kicks in and allows pressure to bleed off. Which is the hissing/groaning noise you may have heard before. That brief moment of extreme pressures is the most common causes of failures in power steering pumps along side dry steering while not moving. If you have shudder going both ways, you will need a new power steering pump because it is worn out. If you get a shudder in one direction and not the other, then you will need a power steering "Rack and Pinion" assembly. If it was my car, I would do both at the same time so you don't have to worry about the other component going out later on and starting the whole process over again. I hope this info helps!
Aug 14, 2014 | 1999 Subaru Forester
What does the A/T eco switch do in my 2002 forester XT
It seems to turn the Eco light on in the dashboard. It doesn't really affect anything in the ECU of the car. Its used to show you if you are driving economically. Accelerate hard or go over 110 km/hr and the light will turn off even if the switch is on. The hold button keeps the car out of first gear so it will take off in 2nd and will try to change to 3rd or 4th as soon as possible to stop sliding on snow or ice. Hope this helps.
Jan 01, 2011 | 2002 Subaru Forester
Inertmitant low idle after flat battery
May 18, 2010 | 2004 Subaru Forester
Subaru Forester 2005 2.5 XT....where is the Power
sounds like you broke a belt i would look there first!
Oct 24, 2009 | 1998 Subaru Forester
Loud hissing noise on 02 wrx under acceleration. Boost gauge showing the correct boost level but no power though.
Oct 13, 2009 | 2002 Subaru Impreza
Audi a4 whirring acceleration noise
Hi i have 02 audi a4 slimline. on motorway going 70 mph and to past a car dropped it down to fourth gear probly hit 90mph. Drove for a further hour and a half, and hear a bang under car. car started to loose power. was drivable but hissing noise come out of it when accelerating. Feels like turbo not kicking in. Would this be that the turbo has blown of maybe burst pipe or something. If anyone can share a light on this i would be very greatful. Cheers
Aug 02, 2009 | 2003 Audi A4 Cabriolet
Engine is making hissing sound.
That hissing could be a vaccuum system leak, have youe tried pinpointing the sound from under the hood?
Feb 19, 2009 | 2005 Chevrolet Trailblazer Ext
Loud engine whine (like a jet noise) from 2002 subaru forester
Have you crawled under the vehicle and personally inspected your exhaust line from manifold to tail pipe? The roaring sound usually occur when there is a hole in the exhaust line. I had it happen to my forester before. A hole half the size of a dime made my subaru sound like my old 74 chevy pickup.
Dec 06, 2008 | 2002 Subaru Forester
2003 forester - there is water leaking in the front passenger side floor when the air conditioner is running. sometimes a hissing sound also in the same area.
You need to clear the condenstate drain for the AC evaporator core, it is under the car, as far as the hissing, sounds like a vacuum leak, look for a disconnected small hose around the area of the noise.
Aug 04, 2008 | Subaru Forester Cars & Trucks
Subaru 2011 Forester 2.5 XT Touring Logo
52 people viewed this question
Top Subaru Heating & Cooling Experts
ray gallant
Hank O
Level 1 Expert
Bill Boyd
Are you a Subaru Heating and Cooling Expert? Answer questions, earn points and help others
