Question about Edge 2003 Ford F-250 - 7.3L Power Stroke - CTS Evolution Programmer
It wont deliver power to the fuell pump fuse all good fuell pump work whit a jump cable
The hot wire wont deliver power to the fuell pump, only works use a jump cable fuese are good,the only way start is whidt start fuell thats the only can start
    Top Expert:
  • Edge Master
  • 10,875 Answers
Trace the wire back to the fuse,if or run a wire from the fuse to the pump
Posted on Apr 08, 2015
Fuel pump wont run with key in on position,only when its cranking.
You know that how?
What testing told you that?
I would only be guessing (that is all we do here)
But it sounds as though the ignition switch is worn
& effects the fuel pump circuit, when in the on position,maybe!
Get yourself a wiring diagram & see how the system should work,
then test it at different points that are accessible
Jul 16, 2014 | 2000 Hyundai Elantra
Tip
Electric fuelpump does not seem to be working
  • Rank: Guru motors_small.png
  • Rating: 86%, 613 Votes
First trace the fuel pump fuse to the battery and, make sure you have power to the fuse you may need to replace the old wire from the battery to the fuse, if the power goes to the system relay but, doesn't come back out; replace the bad relay; still not working? next:
Connect a long 18 gauge wire between the fuel pump + or, positive (hot) connector and, the battery momentarily and, listen for the fuel pump motor to "buzz" If it does remove the wire and follow the hot wire up to the hidden relay; jump the relay, if it buzzes the fuel pump; replace the relay, if jumping the relay didn't work and the fuel pump still does not "buzz" check the pump ground: connect a wire between a bare, unpainted area on the frame and, the - negative (ground) fuel pump connector start up the fuel pump, normally if it now buzzes replace the ground wire or, scrape the place where the ground wire attaches to the frame and, re install the ground screw.
on Jul 16, 2010 | Motorcycles
Whole fuel system
The main fuel pump in a Volvo is really well built and rarely fails (Bosch simply makes great fuel pumps). A good survival trick if you think a main fuel pump might be bad... give it a quick tap with a wrench. For best results, if possible, tap the pump when cranking the engine (while power is going to the pump). If the pump is bad, often the tap will make it come to life and it may stay running until you shut it off. This trick can get you back on the road and get you home in an emergency. If it's a bad fuel pump relay, this will NOT work as there will be no power going to your pump. If this is the case, you might try the below relay bypass "jump" trick to get power going to the pump. TESTING YOUR FUEL PUMP
How to "JUMP" the fuel pump circuit at your Volvo 240 fuse panel:The fastest method to make the main fuel pump run (bypassing the Fuel Pump Relay) is by jumping two circuits at the fuse panel (left side driver's kick panel).
You can make a jumper from a wire with stripped ends or even a straightened paperclip. Jump the circuits on the right side of the fuses for best results
For a 1979-84 240, jump fuse circuit #5 to #7.
For a 1985-93 240, jump fuse circuit #4 to #6.
If the main fuel pump doesn't begin running when jumped (you should definitely hear it humming), you either have a faulty fuel pump or faulty wiring to the pump (bad wiring is really common under an old 240, near the pump). This test of course assumes your battery is good.
If one of the fuses blows during this test, the pump circuit wiring is shorting to ground somewhere between the fuse panel and the pump.
thx
Jan 18, 2012 | 1984 Volvo 240 Series
Power windows wont work.Fuse good
The switch or the motor is out. Remove the wire from the motor and hit the switch. If no voltage registers on a meter jump a hot wire the motor if it works then the switch is out. If nothing then the motor is out.
Jul 19, 2010 | 1999 Buick Regal
1986 944 Turbo wont start.Just died on me going around corner,will start with starting fluid.
It sounds like you don't have sufficient fuel.
Do you hear the fuel pump turned on when you put the key on?
If it is not, need to check the fuel pump relay.
Jump wire at the fuel pump relay to to turn it on to see if Fuel pump is working
Need to check if the fuel delivered to fuel distributor in spec.
Jump wire your relay 60s to check how much gas delivered to the fuel distributor, by disconnecting the gas input at fuel distributor and catching fuel in a calibrated glass container. The gas quantity ml divided by 60 sec to have a flow ml/s. If this is not meeting spec then change the fuel pump. Good luck.
Jul 18, 2009 | 1986 Porsche 944
A/c blower not working
Check fuses and relays (refer to the owners manual for location). If everything checks OK, take a test light and check your wires leading to the blower motor to verify you're gatting power. If so, replace the blower motor. If no power to motor, your problem will be in your switch.
Jun 10, 2009 | 2000 Nissan Maxima
2000 S10 4.3L Fuel pump stopped working out of the blue. We Put a new Fuel Pump in, new harnes to fuel pump, new fuel filter, new relay, new fuses in IGN C and ECM B fuses. Still the pump will not turn on....
At the fuel pump relay you should have 1 full time hot wire. 1 hot wire when you turn on the switch. 1 ground, and the other wire goes to the pump. Test the ground to be sure it is good. If so then jump a hot to the one that goes to the pump and see if it runs.If it does then you have a bad relay or ECM. You can swap the relay with another of the same # from tour fuse box to test it.There is also a ground on top of the frame near the filler neck, check it too. Good Luck
May 06, 2009 | 2000 Chevrolet S-10
My fuel gauge was not working so my son ran a jump wire for the ground at the fuel pump and now the truck wont start i am afraid he may have shorted something is there a fuse for the fuel pump or a relay...
YES THERE IS A FUEL PUMP FUSE IN THE FUSE PANEL. I THINK HE MAY HAVE JUMPED A HOT WIRE AND GROUNDED IT INSTEAD OF A GROUND WIRE. HOPE THIS HELPS. GOOD LUCK.
May 01, 2009 | Chevrolet 1500 Cars & Trucks
Engine stall no fuel want to check relay and wiring for fuel pump ford pick up 2003 v8
good luck on checking the relay.. its made permantely to the fuse box. Meaning ya cant pull it out or replace it. best thing to do is check power at the pump itself.. if ya got power there.. then the relay is working. also get a fuell pressure check off the fuel rail.. should be anywhere from 55-60 psi..
Mar 08, 2009 | 2003 Ford F150 Regular Cab
Edge 2003 Ford F-250 - 7.3L Power Stroke - CTS Evolution Programmer Logo
145 people viewed this question
Top Edge Video Cameras Experts
Are you an Edge Video Camera Expert? Answer questions, earn points and help others
