The mute light is on thus I have no sound. How do you cut the mute off so there is sound? I have no remote!
  • 954 Answers
Look for a button that has a picture of a speaker with a line drawn across it and try that. If all else fails, turn off the radio, wait a few seconds and then turn it back on.
Posted on Apr 08, 2015
My samsung tv say on mute and can't go to unmetered?
It could be a stuck button on the remote.
Try this:
Turn off TV.
Turn on at the TV, not the remote (push screen just above the Blue Light thing at the bottom if no Power button is displayed). If you have sound it was the remote.
Clean the remote of any sticky stuff with compressed air or very lightly with alcohol. Do not use WD-40, it will stick again.
Good luck. Please rate this answer 4 stars if helpful.
Sep 10, 2017 | Samsung Computers & Internet
I have no sound on my TV whether I am trying to watch regular TV or watch a DVD.
The Audio control and circuit board may have shorted due to a power outage or surge. Your VIDEO section seems unharmed, thus I conclude the Audio is damaged.
Mar 30, 2015 | Televison & Video
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
Apr 03, 2012 | Mitsubishi Televison & Video
I have 42'' PDP monitor. As of last night, there is no volume. Pic is fine.
Ilene,
sounds like a) your audio amplifier IC chip is fried, or b) cold solder joint to the speaker(s).
Any chance your pet stepped on the "Mute" button on the remote control?
Or perhaps there's a book on top of the remote which is continuously transmitting the "Mute" Infra-red code?
Any chance that someone has selected "external speakers" in an on-screen menu, thus disabling the internal speakers, and sending the sound signal to RCA jacks on the back of the set to which
nothing is attached? perhaps this setting may be called "Surround Sound?"
Dec 22, 2010 | Maxent Televison & Video
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Jan 16, 2010 | LG 42LB1DRA 42 in. LCD Television
No sound
I know this sounds stupid but when was the last time you replaced the batteries in the remote? Can you use the TV volume button to change the volume up out of mute?
Sep 14, 2008 | RCA TruFlat 27F520T 27" TV
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
50 people viewed this question
 Grubhead
Grubhead
