Question about LG FLATRON W2361V 23 inch LCD Monitor
How to open the monitor's case - LG FLATRON W2361V 23 inch LCD Monitor
  • Anonymous Apr 15, 2015
    a very helpful answer
    Novelist:
  • 242 Answers
Take off the stand and look around the edges where the front case meets the rear case (clamshell). You need to insert a flat tool like a paint scraper (preferably plastic) between them and rock the two apart (you will be able to tell which direction to pull once you start. You should see a section that allows you to begin at.. usually in the middle of one side or bottom. do not begin at a corner.. pry the front and back apart and you will hear the clips pop as they release to seperate the two halves of the "clamshell" and the rear of the monitor will seperate. Just be careful and try to not bust the clips off as you work your way around the monitor perifory.
Posted on Apr 10, 2015
    Master:
  • 301 Answers
Give this a try
Monitor Repair Tutorial
Posted on Apr 28, 2015
How can I open the case of a Sharp LL 172A-B 17"
Gently pull the frame off because they have lock latches.
Nov 11, 2010 | Sharp LL 172A-B 17" LCD Monitor
I have a viewsonic vx1940w Monitor which will no longer power on. I'd like to take the back off and see if there are any loose connections but there are no visible screws. Does anyone know how to open it?
There is no exact instruction, but first thing you have to do is to remove the stand, then starting at the bottom edge of the case using thin flat blade screw driver to pry open the case up and then work your way around the case, you can also look at YOUTUBE, just search for 'how to repair LCD monitor', 'How to open LCD monitor'
Bad caps (leaking/bulging top) are common failures.
http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | ViewSonic VX1940w LCD Monitor
How to open an LCD monitor.
I personally haven't worked on this monitor, but most monitors are held together with plastic clips on either side of the casing.
After removing the stand and all other screws, you will need to use a small flat-head screwdriver (or something of that nature) to pry apart the clips. Find the crease/gap in the plastic where the casing of the monitor comes together. Insert the screwdriver and gently twist and pry the casing apart. When you hear the first click/snap indicating the first clip has come apart, follow the gap with the screwdriver, prying it apart each time you reach an area of resistance. Do this all the way around the monitor.
Keep in mind that after you open up all the clips, the LCD panel and boards may be screwed either the front casing or most likely the back casing. So you must first unscrew the mounting screws inside the monitor to remove the back cover. Also be careful unhooking ribbon or speaker cables that attach the circuit boards of the monitor to the front casing.
Jan 12, 2010 | Gateway FPD2275W LCD Monitor
Need to open the case on an ACER 24" LCD Monitor
You are advised to take it in to an authorised technician for repair. Never open the case unless you are qualified and certified.
Jan 02, 2009 | Computers & Internet
How to open the casing of my LCD Monitor Model HP w 1907v
I have a problem of opening the casing of my LCD Monitor, I want to open it so that I can visually check inside.
Jun 19, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
How to remove back cover of monitor
Here are the instructions to open the monitor:
http://josepino.com/?open-samsung-back-cover
"Don't kill yourself just to save some bucks"
Good luck.
Nov 04, 2007 | Samsung SyncMaster 550S Monitor
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
LG FLATRON W2361V 23 inch LCD Monitor Logo
291 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
