Wash stops on 33 cycle mark, goes to 31 then back to 34 then cuts off. Wpre6100g1wt.
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
Timer is bad
Posted on Apr 08, 2015
OL before spin cycle starts
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
What area code is 3 in the philippines
Region 6 - Telephone Area Codes in Philippine Destinations and Provinces Destination Province Code Region 6 - Aklan Boracay Aklan 36 Kalibo Aklan 36
Region 6 - Iloilo Alimodian Iloilo 33 Banate Iloilo 33 Dumangas Iloilo 33 Estancia Iloilo 3397 Iloilo Iloilo 33 La Paz Iloilo 33 Passi Iloilo 33
Region 6 - Antique Antique Antique 36
Region 6 - Negros Occidental Bacolod Negros Occidental 34 Bago Negros Occidental 3461 Binalbagan Negros Occidental 34 Cadiz Negros Occidental 34 Esclante Negros Occidental 34 Hinigaran Negros Occidental 34691 Isabela Negros Occidental 34 Kabankalan Negros Occidental 34 La Carlota Negros Occidental 34 La Castellana Negros Occidental 34 Manapla Negros Occidental 34 Silay Negros Occidental 34 Tangub Negros Occidental 34 Victorias Negros Occidental 34
Region 6 - Capiz Pontevedra Capiz 36
Dec 23, 2010 | Computers & Internet
General electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
Feb 25, 2010 | Washing Machines
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Nortel NetDirect error on Vista
Hi kt_rutherfor, Firstly apologies for my late reply. I thought that this was going to be a firewall problem, but looking at your error again, I now dont think that. So I'm afraid that I dont know the answer to this, I do have an idea, after researching the problem that this is a Remote-NDIS host problem. Your Uni should be able to help you with this even if it isn't at there end.
Again sorry for not being able to help
Apr 07, 2009 | ASUS T3200 Notebook
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
LG Front Load Washer
This model automatically detects the load size and optimizes the washing time however I do not believe the it should get stuck as you say... try this.. load the washer and then using the control knob.. select Normal.. then push the Quick cycle button on the right.. select the soil level button until it displays 31 minutes.. and run that.. if after you run a wash load it continues to display or get hung up on a specific number such as 7.. your control board may be defective.. If its warranteed.insist they replace it.. Hope that helps...
Aug 10, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
