Question about GE Refrigerators
My GE refrigerator is no longer cooling. Model GSH25JSTC SS. I just replaced the mother board WR55X10942 and it is still not cooling. Water dispenser, fan is working fine.
    Top Expert:
  • GE Master
  • 51,186 Answers
Call the service repairman might need freon added
Posted on Apr 08, 2015
    Top Expert:
  • GE Master
  • 12,962 Answers
Is the compressor running? Is it any good? Is the thermostat control working and cycling the compressor on? Is the self defrost mechanism stuck in defrost cycle (shuts down compressor), etc?
Is the motor getting power?
U need to check all of these areas.
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Posted on Apr 15, 2009
MNTECH
  • 1543 Answers
SOURCE: GE GSS20IEPHWW side-by-side refrigerator stopped cooling
First off, when the fans are both running, the compressor should also be running. Sometimes, because they run quietly, it is difficult to tell if they are running. Touch the compressor to feel for heat and / or vibration to confirm running. (if the compressor gets too hot, the overload will stop it until the compressor cools down. That could happen with too low or too high voltage, even with the cooling fan running) You did not say how long you let the unit defrost. To properly defrost it, you should empty out the freezer side, remove the shelves, and take the metal cover off the back inside wall of the freezer. Then, use a hair dryer to melt all the frost off. If the coils were blocked with frost, you probably have a burnt out defrost heater (located at the bottom of the cooling coils) when replacing the defrost heater, use part number WR51X10101 and follow directions, as it may have a different configuration than the original heater. A frost blocked evaporator (coils inside the freezer) will stop normal air circulation inside the refrigerator. Cold air will then be able to flow backward, into the bottom of the refrigerator side through the normal return air duct located at the bottom of the refrig / freezer divider. This cold air can freeze the water line or water reservoir located there. There for, solving your defrost issue most likely will also solve your water line freeze issue.
Posted on Nov 21, 2009
aasc
  • 1606 Answers
SOURCE: My GE SS Side by Side Refrigerator is not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Posted on Dec 16, 2009
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
My refrigerator temperture display doesnt work and any of the both sides work, the lights work so I know theres power to the unit but it wont freeze or keep it cold.
DO U HEAR THE FAN AND COMPRESSOR RUNNING? U CAN CHECK UR COLD CONTROL THERMOSTAT ( THE ONE WITH USUALLY AN ON /OFF SWITCH) BY PLACING A SMALL SCREWDRIVER INTO THE TINY SLOT OF HOLE AT THE BOTTOM OF IT AND TURNING IT CLOCKWISE TILL U HEAR A CLICK SOUND, DID THE FAN AND COMPRESSOR COME ON?
Mar 10, 2015 | GE Refrigerators
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
I have the GE GDS20SBSS only 6 years old. I paid about 1200$, and I have been advised to buy a new refrigerator. The freezer works but the refrigerator won't keep cold temp. There is frost in the...
Oh my God that's crazy. You can change this yourself part number WR55X10942
Bi Coastal Appliance Parts 1-800-673-1262 around $150.00 + shipping
Sep 14, 2011 | GE GDS20SBS
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
My GE Fridge is making a clicking noise and Digital display out
Replace the mother board. (part # WR55X10942 )
Aug 21, 2009 | Refrigerators
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
