How I remove the default setting from the bottom of the screen? Model No. LE39A316 Hitachi Flat Screen
SOURCE: S video cable not recognized on Hitachi flat screen
I thought the TV had two S- video inputs... It doesn't. Pne of them was an out put and it was there that i had it plugged in. Once i switched it over everything was fine.
Posted on Feb 09, 2009
ripleymojica
  • 643 Answers
SOURCE: can't get rid of red screen on Hitachi flat screen
panel is bad not economical to fix. usually main procecing board.
Posted on Jun 03, 2009
  • 11800 Answers
SOURCE: I have a Hitachi CME LCD 201 Flat screen TV and
Just the exact model and serial numbers. Or you could search for a "universal" remote that supports it.
Posted on Jul 10, 2010
Macklintok
  • 122 Answers
SOURCE: I have a SAMSUNG model HL-T5076S flat screen TV.
Acording to the user manual there is an indicator light that Blinks and turns off when the power is on and lights up
in stand-by mode.
This information can be found on Pages 6 & 7 of the Owner's Instructions wich can be found here:
Posted on Sep 16, 2010
james tv man
  • 91 Answers
SOURCE: I have a Hitachi 47
If those lines are completely thru top to bottom,you may have a defective plasma panel. That will not be feasable to repair
Posted on Aug 31, 2011
How to remove the labels scrolling at bottom of screen
Would you mind telling us the model of Hitachi television?
May 01, 2013 | Televison & Video
I would like to remove the digital display boxes at the bottom of my hitachi tv screen
If you are using a sat or cable box check its menu first to make sure where the display boxes are coming from.
If from the set usually just go to the indicated item in the menu and UnCHECK it.
A owners manual should be available if you do not have it either on the Hitachi site or by GOOGLE the model number with the word manual after it.
Mar 16, 2012 | Hitachi Televison & Video
We have a 40" Hitachi ultra vision model # 42HDT52 plasma screen TV. We have never been able to remove the " written words" off the screen used for the deaf. We have comcast if you need to know that. Terri...
Closed Caption has to be in the menu on the set. Go under the Audio section, find CC and turn it off. This will be the same if you are using a Cable box. They also will have a closed caption setting.
Sep 18, 2009 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Bug parts or debris between screen cover and screen.
All from the front. Pull off the bottom speaker grill. No screws just pull straight back. There are rubber post that hold it. Next remove the screws on the bottom of the screen assembly. With them off you should be able to slide the screen assembly up about 1-2 inches and take off. This model does have auto convergence so the screen may have wires hooked to the back. With the power off disconnect the leads before setting the screen assembly down. Cleaning should be with a plastic cleaner not windex. If you do have to remove screen parts it's fairly obvious. Be sure to reassemble the same order and make sure you have help these parts are delicate when separate.
Mar 22, 2009 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 48
If you wish to get some details; visit the site linked here. Pull up older posts.
May 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi TV screen adjustment
in the menu , the display or video settings should have different video display settings such as 16:9 , 1:1 , 14:9 ect... these will change the video display to different sizes
Oct 09, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Apr 13, 2008 | Televison & Video
Removing the screen from Hitachi 46W500
Pop the speaker cover off and then remove the screws holding the two small black covers on either side, then you will see the screws holding the bottom of the screen.
Sep 05, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
