Question about Miller Welding Tools
Miller big blue 400D welding machine.ran good all day but would not idle down,got home and would not start.starter wires burn.wtf
  • 2976 Answers
SOURCE: I have a miller generator/welder and the starter
Put the diode back in but check the polarity. If removing the new diode corrected the problem, the new diode was in backwards.
Posted on Apr 23, 2009
SOURCE: power mig astro power 110 burns wire off at tip
I have the same welder. Worked well for 15 years until the drive bearing stopped spinning. I cleaned and oiled the bearing and it has been working like a coon on the farm since. Nice 120 volt welder....
Posted on Jun 07, 2009
  • 23 Answers
SOURCE: I have a Miller 225G plus. it idles up good and
Take off shroud, look at where the positive lead hooks into the transformer. You may find that the wire has melted, If you are lucky, you can loop it tnough to make a fresh connection. (also check the negitive)
Posted on Dec 25, 2009
luis_david
  • 407 Answers
SOURCE: I have a miller trailblazer
Hi:
Probably your machines just overloaded; the engine will run and produce voltage but no weld output.
Check your fuses F1 and F2, if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Posted on Apr 28, 2011
SOURCE: have a miller trailblazer 302.
Hi, well i am sorry to tell you but one should NEVER "Jump Start" a machine such as this... replacing the battery with a good one well OK, starting from another Car, Truck, system & battery is BAD.
This procedure is usually done by simply paralleling the remote battery across the existing battery, this can and will often cause damage, sometimes one may "Get away with it" but on the whole it will damage things..
I think H & 0 error codes, have to do with the charging system?
It will most likely be this, "Jump starting" that has damaged the electronics in the system? In any event a flat battery is a no no.. there should be no condition that the battery should have gone flat? It should have been charged up via the recharging system inbuilt into the W/G. Of course this may indeed be the problem, as in there is a existing fault that caused the battery NOT to be charged?
Neither of those CB's has very much bearing on anything, unless they are "Tripped" which from what you indicate they were not. There are no other fuse panels etc to my knowledge?
You are going to have to get in a professional as if what i suspect is true then you will need certain electronic boards replaced.. only a thorough professional testing and inspection will tell.
If one ever MUST remote start any battery started device FIRST one must completely remove the battery connections from BOTH ends, and then and only then, may one connect up the jumper cables, always using the Earth which is connected First, and then the Positive, Remote terminal first then connect to the device. To disconnect the reverse is followed, the Positive is removed from the NON Remote end, FIRST, then the other positive end from the remote terminal, then the Earths can be removed. This will stop any spike surges or other "nasties" from .affecting the system.
Posted on Jun 17, 2011
I have a Miller blue star 3500 with electric start Honda engine.
Have you stripped and cleaned out carburettor?
sounds like a blocked idle jet?
Dec 27, 2016 | Miller Welding Tools
Ran good all day but would not idle down,got home and would not start.starter wires burn.wtf
When it was idling too fast, you were running your engine too hot and should have turned it off. That is probably what caused the wires on the starter to burn. Kyle McFadden says: "The usual cause of abnormally high idle speeds are vacuum leaks or an inoperative idle speed control " idle. The oxygen sensor will detect the extra oxygen that is entering the engine through the vacuum leak and will signal the computer the exhaust is lean. The computer in turn will then provide additional fuel which will result in an abnormally high idle.
Apr 08, 2015 | Cars & Trucks
My miller blue star 185 wont idle up when you start welding
Check your idle control module,
take the roof off of your welder, located at the top right of the inner control panel, it is the little red box with multiple white leads connected to it and labeled with alphabet letters.
pull the connectors, insure they are clean, reconnect them, start your welder and see if that corrects the problem, if not, you will need to purchase a new idle control module
Feb 25, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Dec 12, 2014 | Bobcat Miller 225 Welder Generator 907209...
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Mar 24, 2010 | Miller Welding Tools
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
149 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
