Question about Epson WorkForce WF-2540 All-in-One Inkjet Printer
Printing space is 5.5 x 8.5 and printer does not offer the setting
Printing invitation, if I use the standard letter setting they are coming out either above the margin line or below too far left or right of the margin. 5x7 is too small, legal too long. I'm stuck
    Top Expert:
  • Epson Master
  • 10,875 Answers
rey jr
  • 149 Answers
SOURCE: epson printer troubleshooting
hi there, you do have a ribbon cable problem, the white strip wire which is connected to the head of the printer. repalce the ribbon head cable and add some cleaning and lubrication on your printer machine. ty
Posted on Dec 24, 2007
  • 514 Answers
SOURCE: Printer prints off-center when printing from
if you are not printing graphics from the site, try doing a "print pre-veiw first to see if that will help, otherwise it will take a little experimenting with the print settings to find out what will and will not print the way you want it to. try also saving the the page to some thing like notepad or such and then trying to print. good luck!
Posted on Apr 11, 2009
gpcomputer01
  • 137 Answers
SOURCE: The top half of letters on certain lines of print
This usually indicates a need for a new print cartridge or the printer head is dirty. You can run the automatic printer cleaning utilities. Note: do them several times.
Also, if you are a little handy, use Qtips and rubbing alcohol and clean the print head.
Posted on Sep 18, 2009
  • 8404 Answers
SOURCE: Why won't my printer print on vellum paper?
Im guessing ...
I had a similar experience with a different brand ...
Your printer thinks it grabbed two sheets of paper.
Open your priter program (in the control panel) and see if there is a setting for Vellum
I hope this works for you
a
Posted on Oct 13, 2009
  • 10 Answers
SOURCE: How can I print invitations size 5X7 on this
You need the driver setings on your pc, select the correct paper type or media type then select the size if this size is not available you can create a custome paper size one the driver but you must take into consideration on how thick is your paper you can set the media thicker setting all this option is available on the printing preference (windows) or print settings (mac).
hope this help
Posted on May 31, 2010
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
How to print 5 X 8 invitations on an HP Photosmart C309a printer
I think it's more or less the same on Mac or PC. Hit Print in your software, then when the dialogue box comes up you should see several options settings. There will be a pull-down menu that lets you choose paper size. (This menu is sometimes buried in another sub menu called "printer options" or something similar. It can be tricky to find this in some apps like Photoshop). Just select your 5x8 size and then at the top of the dialogue box you should be able to save it all as a preset. Pull down the "preset" tab and select "Save As..." then you can name it and pull it up each time later.
Hope this works.
Oct 28, 2009 | HP Photosmart Premium C309A All-In-One...
How to print an invite
You need special software for that, any printer can do it. If you go to a website that offers invitations, you can print from there and they tell you how to insert paper, what size etc.
Aug 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
How much ink is left?
Tip: If you're printing invitations, you're going to use a lot of ink..get a spare set of ink.
No. There is no way to know how many more pages, because, if you think about it, printing a photo (or invitation), obviously uses far more ink than, say, a letter.
Apr 07, 2009 | HP Deskjet D4160 InkJet Photo Printer
Printing 5x7 invitation
use the mpf tray. go to the machine press menu down arrow untll you get to tray settings. right arrow over till u get to paper type...then down arrow till you see paper size...right arrow again till u see tray 1...down arrow till you see mpf..right arrow till you see letter. Now that you are in the mfp section you can down arrow and you will see serveral selections I would keep it at letter. when you select it an * will appear next to letter. Then select menu and you and the printer is set. Now go to the print option in the program that you are using and when the dialog box to print opens select properties. go to paper quality the mpf should be selected in the tray souce. Now go down and you will see the advance button, click on that you will see Paper/Output make sure it says Paper Size and Letter is selected. Media Type should say Plain 1. If the invitations is on a heavier paper like card stock click the down arrow and select Covers 1 . If your paper is coated like matte finish photo paper select Coated 1. Now click ok. Do a test print and see if you get what you want. If not, let me know.--Deeva
May 21, 2008 | Dell 3100cn Laser Printer
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
Epson WorkForce WF-2540 All-in-One Inkjet Printer Logo
125 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
