Question about Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12
Lost xanbus system light out on inverter all other systems working except auto gen start and silverleaf info panels
3 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: I have a trace inverter DR 1512, I am having a
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Posted on Feb 25, 2010
  • 25 Answers
SOURCE: Trace, no power from line one from either gen set or shore power. Have rebooted, and when I invert the coach works normal. Charge system to house and coach batts perfec
If a normal install, the shore power and generator will go through a transfer switch then to the inverter. If when inverting 120 VAC circuits are OK, then the problem must be before the inverter. I would suspect that it is the transfer switch.
Disconnect shore power, make sure generator in NOT running then take a look at the transfer switch these are in a boat or RV but either can lead to vibration problems which can lead to loosening wire connections which can lead to heating and burning. It may be something as simple as a wire coming loose. (Which could be dangerous!)
Whether or not the contacts in the relays are OK, check and/or tighten all electrical connections. It's a good idea to check and tighten all electrical connections regularly.
Some transfer switches can be repaired by replacing just the relays. Other units (like mine this year!) will need to be replaced entirely.
Posted on Nov 11, 2013
Why isn't my 1st Gen honda insight ima battery not charging?
Test,s would have to be carried out,could be a technical problem.
Jul 19, 2014 | Honda 2003 Insight Electric Rear Catalytic...
Kubota GL11000 Diesel generator starts out delivering 120 volts, and within a few minutes will drop down and stay at 90 volts. Any ideas?
Is there an auto/man switch? Try both ways, just to see if the problem is in the auto controller. I believe on man it runs at high speed all the time, on auto only when it senses load. So, if the inverter doesn't draw, it backs off.
Nov 30, 2013 | Electrical Supplies
Stanley 300 amp jump-start system status lights don't work. only low stays on
Sep 26, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
I have a problem w the auto Gen. start turning the Gen OFF once it has started it. The lowest voltage setting to turn it off is 14.0vdc the problem w this is it will never reach that voltage. So I set the...
Your experience matches my own. I think the only solution is to use a DC monitor such as the Victron unit which has an external relay. Hook up the relay contacts to the Temp in on the AGS, then set the Victron to trip the relay when the batteries are charged to whatever percent you decide, such as 80%. Use the DC volts to start the gen and percentage of charge to turn it off......
Nov 17, 2010 | Xantrex Technology Xantrex RS2000 Sine...
I recently bought a used 2004 Fleetwood Discovery 39L with a Xantrex Freedom 458 system in it. The system worked (sort of) for the first few months I owned it, but now fails to charge the house batteries....
It sounds as if your inverter has failed altogether. This failure could also be caused by power management having issues.
So far, I know that you have a 2004 Fleetwood Discovery 39L. If memory serves, this is a *30AMP* chassis, with 2 air conditioners, using an intellitec power management panel located above the driver position. If I am incorrect, please advise.
Aug 18, 2010 | Xantrex Technology Xantrex Freedom Xmic...
2001 toyota prius main battery failure
Always have your battery tested first. They will get a print out of everything from a good battery tester.
Mar 20, 2017 | 2001 Toyota Prius
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Kv 27ts27 set works fine except lost color. now black and white
pls check and selact in your tv colour system PAL / NTSC / AUTO
set Auto colour system is Best .
set chennal Auto serch
if not
then problum is in side tv pcb. so repare pcb with nr. thech.
Oct 30, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Logo
164 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
