I had turned my sansa e250 off because almost all of the tracks had turned bad and now it will not leave the first screen after the first screen it turns white and goes back to it... what do i do?
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
i have the same problem. ive tried many things. i tried the website you have given but its saying file not found then goes to something else
