Question about Kitchen Ranges
How do you remove the upper front panel of range to access a loose switch that is causing the exhaust fan to run when the burners on left side are turned on?
    Top Expert:
  • 10,875 Answers
Pull up on the front edge of stove to open it
Posted on Apr 08, 2015
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
I have a MH6150XMQ Whirlpool Micro and the light comes on with the fan but it does not heat nor does the turntable rotate. The turntable is turned on via the front push button. How can I troubleshoot this...
While the turntable can be prevented from running while cooking if you turn it off with the keypad, that's probably not relevant here.
This problem is usually caused by either a bad upper door switch or a loose door switch mount, which are pretty simple problems to fix.
My help file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 12, 2011 | Whirlpool MH1150XMQ Microwave Oven
How to install a alternater for a el dorado 97
FIRST TURN OFF RADIO SO YOU WONT LOSE PLAYING CODE BEFORE DISCONNECTING NEGATIVE BATTERY CABLE.REMOVE THE COVER FROM THE HEAD LIGHTS AND THE RADIATOR SHROUD. REMOVE AIR CLEANER ASSEMBLY. DISCONNECT THE LEFT ENGINE TORQUE STRUT.DISCONNECT THE UPPER TRANSAXLE OIL COOLER LINE.REMOVE THE RIGHT AND LEFT COOLING FANS.REMOVE THE SERPENTINE BELT FROM THE ALTERNATOR PULLEY.REMOVE THE BOLT FROM THE FRONT TOP AND THE LOWER FRONT OF THE ALTERNATOR.DISCONNECT THE HARNESS AND OUT PUT CABLE FROM THE ALTERNATOR.REMOVE THE BOLTS FROM THE ALTERNATOR REAR BRACKET -.NOTE - THE BOLT NEAREST TO THE EXHAUST MANIFOLD CANNOT BE REMOVED FROM THE BRACKET BUT CAN BE BACKED OUT ENOUGH TO ALLOW FOR ALTERNATOR REMOVAL.REMOVE THE AC SPLASH SHIELD.REMOVE THE ACCESS PANEL FROM THE BOTTOM SIDE OF THE RADIATOR SUPPORT AND DISCONNECT THE HARNESS CLIP FROM THE CRADLE. MOVE THE ALTERNATOR AWAY FROM ENGINE. AND OUT FROM THE BOTTOM SIDE OF THE ENGINE COMPARTMENT. TO INSTALL THE ALTERNATOR TO THE BRACKET WITH THE BOLTS TO THE REAR OF THE ALTERNATOR.HAND TIGHTEN THE BOLTS. CONNECT THE HARNESS CLIP TO THE CRADLE.INSTALL THE ACCESS PANEL AND AC SPLASH PANEL.CONNECT THE HARNESS AND OUTPUT CABLE TO THE ALTERNATOR.TORQUE THE OUTPUT CABLE TO 15 FT LBS.TIGHTEN THE REAR MOUNTING BOLTS TO 36 FT LBS. INSTALL THE BOLTS TO THE LOWER FRONT AND FRONT TOP OF THE ALTERNATOR AND TIGHTEN TO 36 FT LBS.ROTATE THE DRIVE BELT TENSIONER AND INSTALL THE SERPENTINE BELT.INSTALL THE REMAINING COMPONENTS CONNECT THE NEGATIVE BATTERY CABLE.RUN THE ENGINE AND CHECK CHARGING SYSTEM OPERATION.
Mar 22, 2010 | 1997 Cadillac Eldorado
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
Advantium 120 - Panel is dead, exhaust fan and lights working.
Chances are you have a bad primary interlock (upper door switch) or a loose or damaged door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Jun 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Jenn air range, model CVG4280B, repair, ignitor problem. Ignitors will not work on any burner. Burners can be lit manually. Power is available at the electical box. Fan comes on when either burner turned...
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Apr 26, 2008 | Kitchen Ranges
Kenmore C880 6587590 burner switch replacement.
I just replaced the switch just yesterday.First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Feb 21, 2008 | Kitchen Ranges
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
