Question about Jandy LXI250N Lxi Gas Pool Heater 250k BTU Natural Gas
Model no. lxi250n my remote says heater offline but the heater works fine in manual
  • dan_galasso Apr 16, 2015
    Xheck the four wire connection and wire going from your heater to your controller. Make sure it is secure
    Top Expert:
  • Jandy Master
  • 3,543 Answers
If all wires connected turn off aqualink then turn back on it should recognize heater
Posted on Apr 30, 2015
    Problem Solver:
  • 7 Answers
Check the four wire connection from the heater to the comtroller making sure they are secure and no breakes in the wire
Posted on Apr 16, 2015
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
What would cause my Brominator to leak from underneath.
If it is an offline model you should be able to turn it upside down while pump is running and see the leak.
May 12, 2014 | Hayward Offline Brominator
Where to find a boiler manual
Hi John
You can find 8,000 free boiler and gas appliance manuals on www.gotogasdocs.co.uk
Hope this helps (If you can't find the model you want let me know as I have a few offline).
Nov 27, 2012 | Heating & Cooling
Error code C4 76. Water heater shuts off (only with shower use). Will reset and work 4-5 min. then off agin. works fine from sinks. Unit is app 3 years old and did work fine.
Before calling service technician, open following link for Rheem tankless resources, including error codes and general help for homeowner.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
C7 76 is communication fault with remote control.
Remote is connected to tankless with a wire.
Usually you remove wires from terminals on tankless, and see if tankless functionality returns.
If tankless works fine, then it will heat to default 120 degrees.
Clean terminals and put them back.
If problem returns, then problem is then narrowed to bad wire, bad remote control, or problem inside tankless.
Since new remote control costs about $99, it might be cheaper to have service technician review the problem and catch up with maintenance.
Error codes are considered starting points for troubleshoot since error can have different soultion than same error on another unit.
Read manual for advisories, error codes, and required maintenance.
For example tankless might require monthly water filter cleaning, and yearly de-liming, and yearly burner cleaning.
Your service technician can advise what is typical for your region, since altitude, incoming water temperature, quality of water, water pressure, venting, are factors for maintaining water heater.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 25, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
I have a NY116 (DESA/Comfort Glow) heater w/ remote control. The remote control doesn't appear to show the room temperature while in Progrom Mode... preventing the heater from turning on. It works fine in...
The remote control was made by Skytech. You should get the information off of the remote and the valve and contact them for parts.
email
support@skytechsystem.com
fax
888-672-8024
phone
888-672-8929
address
9230 Conservation Way
Fort Wayne, Indiana 46809
Jan 05, 2010 | Desa International HRC201-4 Remote Control
I have an HP Photosmaet I have an HP
See instructions to clear the offline condition here. Also helpful may be the HP home support page for your model here, which has detailed instructions for setup and troubleshooting should you need them.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2009 | Office Equipment & Supplies
REMOTE CONTROL DOESNT WORK
Some of the remotes that originally came with those units did not work or last very long. The manufacturer then later offered another remote to replace the first units. It looks like the model number you provided is a serial number, not the actual model number. I suggest that you contact Master Parts at 800-446-1446 with your model number (you should be able to find it directly on your unit with the serial number you provided) and they should have that replacement available for purchase. You also can find them on-line at www.masterparts.net. I hope this helps you!
Oct 18, 2008 | Vanguard International Blue Flame - Medium...
Jandy LXI250N Lxi Gas Pool Heater 250k BTU Natural Gas Logo
253 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
