All of a sudden part of the picture is being cut off (ie., HSN price info only shows up half way, bottom written stuff doesn't show all.
Manual doesn't show how to get this right again (and I don't know why all of a sudden it turned wrong). Please help.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 08, 2015
Testimonial: "THe person who recommended it might be a cable issue - it was. Called cable and they rebooted and now I can see everything. Thank you to everyone though who responded. Made me feel I wasn't so alone in all of this!"
silly girl
  • 513 Answers
SOURCE: problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Posted on Mar 22, 2006
  • 192 Answers
SOURCE: Picture too large
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Oct 14, 2007
Coldcut
  • 1554 Answers
SOURCE: autiovox lcd Half the screen turns blue the other half has virtical lines in it.
Typical of the glue that holds the circuit to the screen coming loose.
it will take a very good repairman to fix this and he will have to know where to find the glue, its special with microbeads embedded.
Posted on Mar 04, 2008
  • 54 Answers
SOURCE: VIZIO GV4VL cuts off the bottom of screen
on the tv's remote you have a button which says one of a couple things. 1) pic size 2) ratio 3) zoom 4) aspect. using that button push it a couple of times until you get to either 16x9 or full depending on the brand of tv you have
Posted on Jan 22, 2009
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
Tv is not showing complete picture....some things are cut off
Change the aspect ratio.this can usually be done via the remote or through the tv menu.normal view for most wide screens is wide 16:9 but if you have zoom or crop black bars then you may lose parts of playback.
Feb 19, 2015 | Vizio L37 Television
Vizio M55------- will not show football scores,time,info
Find the Aspect ratio button on the TV remote. Press it a number of times to cycle through the options. Stop when the picture is the shape you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 15, 2014 | Vizio M551d-A2R 55" 3D LED Smart HDTV
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
I have a 20F42OT - is there someway to change the screen so the entire picture shows? for example, if there are sports scores on the bottom of the screen, you can see only top half. Screen should be...
does the remote have a aspect button? or maybe it is in the menu? If not let me know and I'll look it up. I have worked on some of these but dont remember them being wide screen
May 03, 2011 | RCA 20F420T 20" TV
User manual for motorola C118 mobile phone
Muriel,
The best site for all your mobile needs is www.gsmarena.com. All you have to do is to specify your phone model and make, ie, motorola c118 and the next page would show the phone's picture and specs. Under the picture you will find written 'Manual'. Click here and you would be able to download the manual in .pdf format.
Your manual is at the following site
http://www.motorola.com/staticfiles/Support/IN-EN/Mobile%20Phones/C118/IN-EN/_Documents/Static%20Files/C118_UG_IN_EN_6802923J10_V1.pdf
which I found through gsmarena.
Jan 26, 2011 | Cell Phones
Tv is showing double vision with red being the second image
This is due to convergence out chips failure, replace convergence out ICs in TV to get converge picture.
If you are handy with electronics stuff repair and want to repair TV by yourself (soldering work is required) then let me know exact model number written at back of TV to provide you more technical info OR ask local tech to fix it.
Thanks.
Jan 07, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
