Question about Boating
90 horse mercury outboard tachometer quit working I've checked connections.
    Sergeant:
  • 456 Answers
Faulty tachometer or rectifier or broken wire in loom,check if any current coming out of grey wire with engine running
Posted on Apr 10, 2015
4 Suggested Answers
  • 86 Answers
SOURCE: 15 horse mercury outboard
Clogged jets in the carb...clean out carb or rebuild carb.
Posted on Aug 06, 2009
SOURCE: How do I use the tilt adjustment on my 6hp mercury
asked a boat mechanio, & he explained a circlip and spring are missing.
Posted on Feb 06, 2010
Testimonial: "thanx, I posted this reply;>"
  • 677 Answers
SOURCE: I need to know the ratio of a gas and oil mix for
I'am amazed it doesn't have an oil premix that gives it auto oil mix.If it doesn't than the mixture is 50/1.That is fuel /oil ratio.e.g. 50 litres of fuel to 1 litre of oil.Hope this helps
Posted on Apr 17, 2010
2017 Mercury 90 horse outboard won't go up or down
Is trim motor turning, when switch is engaged? If not, can you hear the trim relays click with switch engauged? Do you have switch on engine as well? Did you check the fuses?
Sep 20, 2017 | Mercury Boating
What year is my Mercury outboard
with out information as to size, hp, band color on the cover, serial number or photo , no one will be able to answer that question
you can go google and type in--- identifying mercury outboard models and types and power ranges --
there are sites that I found quite some time ago from mercury that was pretty good and if you have a serial number and horse power , you may get the answer
of course you could always take it in to a service dealer and have it identified
May 13, 2016 | Boating
Tachometer 90 horse mercury outboard engine quit working any suggestions
Hi Royscarrow,
This Could Be A Few Reasons Causing The Tachometer Not To Work.
The Voltage Regulator Mounted In The Engine Compartment Has A Grey Wire Coming Out Of It Together With Two Yellows,Two Red's and One Black. The Grey Wire Is The Sender For The Tachometer.
Check That It Is Connected.
Is The Battery Getting Charged When The engine Is Running?
Is The Potting In The Regulator Discolored Or Burnt Looking ?
Check The Plug For The Gauge Loom At The Control Box Is In Correctly.
Let Me Know What You Find.
Apr 03, 2015 | Boating
Starter dragging on 2001 Johnson 90 horse outboard
Check batt wires good contact,check brushes in starter have good earth check batt cables have no black death
Jul 31, 2013 | Light Outboard Motor Boat Bass Fishing...
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
My tach stopped working
If it's a machanical tech check for a broen line from the engine. If electric check for + voltage to the tech if ok tech if bad
Oct 14, 2009 | Faria Chesapeake Series Tachometer
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
97 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
