SOURCE: ptid-5300
Its illegal to watch a dvd/tv when the vehicle is moving so the manufacturer disables the function.. Usually by connecting a cable to your handbrake indicator or to your vehicle speed sensor VSS.
Youll have to find out which one it is. You can then find out how to disable it. JVC's normally ground the H/brake cable
SOURCE: ipod cable
you can get it at best buy. ill do some lookin' cause i have a pioneer head unit and i just built that cable. i might be able to do the same for you.
SOURCE: region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
