Question about Jenn-Air Refrigerators
.I cleaned all the coils front and back and the temp remains to be 80 degrees my jenn air stopped producing cold air.This refrigerator is only 7 years old model number jfc2089hpy black glass model.
    Top Expert:
  • Jenn-Air Master
  • 48,549 Answers
Call a service repairman it probably needs recharged and it is not a DIY task
Posted on Apr 08, 2015
  • 4 Answers
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
source: someone else on this site posted this and it works
Posted on Apr 13, 2015
Jenn-air refrigerator too cold
what are your temp control settings frrzer should be about zero and fridge side should be around 39 degrees temp. try setting it lower maybe 3 if control knob if digital check for 39 to 40.
Oct 21, 2013 | Jenn-Air JCB2285KES (21.5 cu. ft.) Side by...
I have a Jenn-air JFC2089HPR Refrigerator. The other day it started leaking water out the bottom somewhere. I turned off the water to the fridge and the leaking stopped. When I checked, all the external...
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Sep 24, 2011 | Jenn-Air JFC2089HE French Door...
We bought this refrigerator last year and have been very happy. However a few days ago the freezer temperature (which should be at 0) has been creeping up to about 8-10 degrees and now the non freezer...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Jenn-Air JFC2089HE French Door...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
My Jenn-air *** has all but quit producing cold although the freezer is still working fine. So is the light on the *** side.......any ideas.....would it be the thermostat? My husband is out of state and I...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jun 15, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-air stove temperature not constant
Sounds like your oven probe sensor has got issues. Pretty easy to fix, just look inside oven for the probe (small round cyclinder, about a pencil width or smaller, mounted usually in the back top corners), remove the two screws, then slide it out. Some models have the probes where you will have to take the back off to get to them. If your probe is ok, then you might possibly have an issue with your main oven control, which may be computer or knob type. These (especially if computer driven) can be very expensive to fix, and some need calibration. Good luck and let me know if you need any other assistance.
Nov 16, 2008 | Kitchen Ranges
Refrigerator freezes things the freezer works fine:
Most common is a dirty condenser coil. If you have not cleaned it recently vacuum and brush the coil underneath and the back bottom compressor compartment. Blocked air flow will cause erratic temps in the refrigerator section.
Jul 28, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn air refrigerator problem
Couple things to check first is that your evaporator fan motor is running, located in the back of your freezer. open the door and listen for the fan some work on the door switch make sure you depress the switch to check it. If the fan is not running more than likely you need a new fan. The second thing is just look at the back of the freezer compartment and look for a layer of heavey frost if there is heavey frost then your defrost is not working, will need to manually defrost and probably replace the defrost terminator part of the heater assymbly
Feb 10, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
97 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
