Question about Garden
I am having trouble lowering the deck on my bad boy
    Top Expert:
  • Garden Master
  • 51,545 Answers
Get out the wd 40 and spray every thing that moves or should move on the lift linkage .some times you might want to tweek the bolts just a little less tight .
Posted on Apr 08, 2015
Bad boy mower wont go in any direction, mower blades work and deck moves
Your issue makes no sense. Read what you wrote and resub in understandable English. How can deck move if it does not go in any direction?!?!?!?!?!?!?!!?!?!!?!!?
Aug 19, 2017 | Garden
I am having trouble lowering the deck on my mower
as most deck adjustments are mechanical control ,the problems come from rusted pivot points on the levers. try some WD-40 or same on all the joints.
Apr 08, 2015 | Garden
Why does the engine die when I lower the mower deck on my Murray lawn tractor?
I would check your belt tension and make sure that it is not too tight.
If you have the manual, try the trouble shooting section for further information.
Aug 28, 2014 | Murray Garden
Precor error code 29
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary
Precor Error Code 29
May 02, 2014 | Life Fitness T3 Treadmill with Advanced...
Why is my Precor Efx 546i elliptical showing an error message?
2. Bad lower PCA.
Corrective Action
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Feb 11, 2014 | Exercise & Fitness
Bad boy mower
need to level deck
Aug 11, 2013 | Garden
I need a diagram for deck belt on a 1989 lawn boy lt 12 38 " deck
it's usually on top of the deck clean off the grass and look on top may have to remove it to see
Oct 19, 2012 | Mtd LAWN MOWER PART # 983-04052 DECK...
What does error 29 mean on a precor C954i?
2. Bad lower PCA.
Corrective Action
Apr 06, 2011 | Precor C954i Commercial Treadmill
What is error 29
2. Bad lower PCA.
Corrective Action
Mar 27, 2011 | Precor 923 LowImpact Treadmill
Lawn boy 2 cycle that smokes
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Jun 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
