Question about Kitchen Ranges
Neither bake nor broiler element heats. Stove top burners all heat. Any suggestions?
    Top Expert:
  • Kitchen Ranges Master
  • 42,108 Answers
When elements are not working the main fault is burnt out elements
next fault is faulty switches or thermostat controls
have an electrician check it out
Posted on Apr 08, 2015
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
May 18, 2015 | Kitchen Ranges
Kenmore electric range c970-535141- broiler and bake elements will not heat. All lights, digital display and 4 burners are working. Any suggestions?
check and see if one of them are loose,most plug in.if that does not work than check the wiring where the cord goes in the back of the stove and check if a wire has came loose..but please unplug the stove first.
Feb 03, 2015 | Kenmore Kitchen Ranges
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Maytag dual oven upper oven not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerryrigging a bridge to wire the BAKE igniter to the BROILER controls.(Push/click plugs accessible by opening up the stove back) Testing thebroiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.)The parts and wiring are pretty simple and visual once you get thecovers off. Opening up the stove back is just a matter of removingseveral screws. UNPLUG the stove before you work. If you test as Idescribed, make all connections while UNPLUGGED and then plug it inonly for the brief test. Unplug again while disconnecting/reconnecting.Hope this helps.
Nov 25, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
