Question about Ricoh Aficio Office Equipment & Supplies
How do I fix the error code SC400?
The error code SC400 appears after every single print.
    New Friend:
  • 142 Answers
I don't know what is your printer model, but I am sure, that this mashine needs cleaning. The main problem should be that the ID sensors of image transfer belt are dirty. You need technical skills to do that.
Posted on Apr 18, 2015
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
Hello. i have Printer Ricoh SP C222SF indicated error code (service code sc400) any idea please
Call Ricoh support, they'll tell you what it is for free and try to sell you service to fix it. 1-800-227-4264 in the US.
Jan 28, 2015 | Ricoh Office Equipment & Supplies
How to fix the error mc2030 Gestetner print accurred SC400?
I can only find a Gestetner MPC2030, so if that is correct, here is the service bulletin on the problem, and how to resolve:
SUBJECT: TROUBLESHOOTING SC400 ID SENSOR ADJUSTMENT ERROR
GENERAL:
Please follow the troubleshooting steps below to resolve an SC400 (ID Sensor Adjustment Error).
1. Check the harness of the ID sensor.
2. Clean the ID sensor with a cloth moistened with water. NOTE: Never use alcohol, because this may damage the board.
3. Execute SP3011-001 (manual process control).
4. If the value of SP3324-003 (Vsg error counter) is NOT"0", repeat Steps 2 and 3.
5. If the value of SP3324-003 is still NOT "0" after repeating Steps 2 and 3, check the spring for the PTR unit contact lever. Repeat steps 3 & 4.
6. If the value of SP3324-003 is still NOT "0" replace the ID sensor. Repeat steps 3 & 4.
Notes:
1. If the black spacers are stuck to the sensor board, remove all black spacers. These black spacers should be used when a new ID sensor board is installed.
2. Input all correction coefficients for the ID sensor with the SP modes referring to the barcode sheet provided with the new ID sensor unit/board. For example, input "0.98" with SP3362-013 & 016.
3. Always refer to the Service Manual for the complete part replacement procedure.
7. If the value of SP3324-003 is still NOT "0" replace the BCU. Repeat steps 3 & 4.
8. If the value of SP3324-003 is still NOT "0" replace the ITB unit.
Jun 11, 2013 | Office Equipment & Supplies
Spc 220n has a sc400 code
Process Control Error
This SC is issued if the process control adjustment fails 5 times consecutively after AIO
replacement.
• Defective contact at the terminal between the machine and AIO.
• Dirty TM sensor
1. Check the contact of the terminal and re-install the AIO.
2. Clean the TM sensor.
Apr 09, 2013 | Ricoh Aficio SP C220N Laser Printer
Me marca error sc400 una ricoh c2030
hola tengo una maquina ricoh aficio mp c2030y me marca error sc400 Que es y como solucionarlo
gracias!!
Jun 13, 2011 | Ricoh Office Equipment & Supplies
Hi all Lanier Ld 520c Error code 400 what is it. Thanks
sc400 is an ID sensor error. You probably only need to clean the ID sensor, rather than replace it, but there's a chance it could be something more serious, like a board or the transfer belt assembly.
Getting to the ID sensor is tricky -- you may want to call a service technician. The fuser needs to be removed and the whole right side door needs to be taken off. But chances are that once that ID sensor is cleaned and the machine is turned off and back on, the sc400 error will go away.
Dec 16, 2010 | Lanier UNKNOWN
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
With a printer/copier Ricoh spc221sf, giving code sc400
sc400 is a process control error. Did you just replace the all-in-one toner cartridge? If so, take it back out and try again -- it might not have been in all the way. If the error still occurs, check the contacts between the toner cartridge and the machine -- they may have gotten bent or dirty.
Mar 08, 2010 | Ricoh Aficio SPC210SF All-In-One Laser...
713 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
