Question about Exercise & Fitness
No resistance after i enter the level and start peddeling
  • 6 Answers
Interfaces to exercise bikes are different between manufacturer and model. If the bike worked before this way then I would recommend removing the power from the bike for a few minutes and then plug it back in. This will reset the computer. If this does not solve the problem then you should contact the manufacturer.
Posted on Apr 13, 2015
Break lights won't go off
Hi there?
The brake light switch is faulty or is NOT secured. When the brake pedal is released it pushes the pin on the brake switch to switch the lights off. If the pin is not getting pushed in proparly then the lights stay on. check the switch. Good luck................
May 30, 2011 | 1999 Ford Escort
Had a clogged brake line changed it bled system no peddel changed calopper still no peddel changed master cylinder got peddel then i start truck loose peddel changed master cylinder again and the same...
You have to have the engine running to bleed brakes
Your need a helper to push the pedal while you crack
open the bleeders
Have to do all 4 corners
Just not bleed,have air in system
Never needed all those parts & you didn't have
a clogged brake tube.
May 25, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Soft break peddel
Sounds like you have a vacuum booster issue or a brake master cylinder going out. If you know of an independent mechanic the Vacuum Booster test is simple. It is recommended to replace both the booster and the master cylinder at the same time.
Feb 09, 2010 | 1995 Buick Riviera
WON'T START, MAY BE RELATED TO THE CLUTCH SWITCH?
If there is one its under the dash someware around the clutch peddel arm, it should look like the breaklight switch with a spring loaded pin that pushes in or relieses out( depending on witch way its set up) when you depress the clutch peddel, or it could be under the hood, either way its got to work off the clutch peddel.
Oct 23, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Starts then dies willrun a bit with the peddel to
fuel pump if your lucky its just a dirty Fuel Filter.
Aug 19, 2009 | 1999 Pontiac Grand Prix
2002 hyundai accent my cluch peddel goes soft
check fluid level if low bleed out the system.If thats fine then you have slave cylinder Problem.Before Changing the cluch assembly check your master cylinder is pushing good pressure.
Jul 17, 2009 | 1998 Hyundai Tiburon
2001 dodge ram 2500 diesel
Probably becuase there is not enough brake fluid in the system.
check your brake fluid level.
Jul 11, 2009 | 2001 Dodge Ram 2500 Truck
How do I bleed the master clutch cylinder
It will take two people, one to push clutch peddel, and one to open bleeder, same as bleeding breaks, the person pushing peddel pumps peddel a few times and the last time holds to floor, other person opens bleeder to let air out, and then closes bleeder while peedel is still depressed, do this process over and over untill you get clutch or a steady stream of fluid with no air , while keeping an eye on fluid level in resavor.
Apr 05, 2009 | 1996 Nissan Maxima
Power terrain problem
Check the oil level in engine.
Dec 23, 2008 | 2004 Dodge Ram 1500
Exercise & Fitness Logo
822 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
