Question about Admiral Refrigerators
I have a" Admiral designer series model HMG24922" Refrigerator, And the freezer keeps leaking out water can anyone tell me how to fix it!??
    Top Expert:
  • Admiral Master
  • 42,084 Answers
If it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Posted on Apr 08, 2015
mikedurland
  • 481 Answers
SOURCE: Admiral model #rswa278a
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Aug 08, 2008
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I have water (condensation?) leaking from under the freezer
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
woodchuck789
  • 4059 Answers
SOURCE: Kenmore refrigerator (model 106.78187891) leaking inside
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 14, 2009
aasc
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the front of the freezer and a build up of frozen water has accumalated at the bottom of the freezer.A person has advised...
hello again,
Sorry to hear that the drain is clear and not the problem, some of the other things that cause that water are;
Freezer door gasket...is it curled up in the corners espicially on the hinged side so air is leaking in and condensating resulting in water
The tube that send water into the icemaker is partially frozen so when water enters the icemaker it's being sprayed and dripping to the bottom(if thats the case ice would probably be built up all over the freezer)
The door for the ice dispenser isn't fully closing and will cause condesation just like the door gasket would
Good luck,
GENE
Oct 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hello i have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the freezer at the front left hand side.there is also a build of of frozen water at the bottom of the freezer.I have...
The most likely source of that water is a frozen/blocked drain for the defrost drain at the bottom of the freezer behind the back wall of the freezer.Its a fairly common problem so i have written this tip explaining how to clean that drain for the defrost.
http://www1.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
My admiral designer series model#HMG621860 is leaking water onto the floor from the freezer compartment where is the drain located on this model, I took everything out of the freezer one week ago and could...
Every freezer have a drip collector beneath it. Some times it may be filled completely with water thus causing an overflow. Else, the opening to the collector is being blocked by some ice. Also this problem can happen with aging of the fridge. There is nothing you can do in particular in this case.
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
864-812-1887
Jul 12, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice repeatedly forms at the bottom of the freezer compartment. Eventually it reaches the door and water leaks out. Signature Series Frostfree Model HMG51108
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral Designer Series
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1737&PPStack=1
Nov 21, 2008 | Dryers
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
108 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
