Question about John Deere Replacement Hydrostatic Transmission Lt150, Lt160, Lt170, Lt180
Easiest way to change mower blades - John Deere Replacement Hydrostatic Transmission Lt150, Lt160, Lt170, Lt180
  • John Deere Master
  • 2,992 Answers
Repair manual. and be careful
Posted on Apr 08, 2015
Testimonial: "This was an absolute un-useful answer. I expected professional advice, and I was answered by a wise cracker."
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
How do i change the mower blades on my honda hru19d
Check this site for changing mower blades. Seems straight forward:
HOW TO CHANGE LAWN MOWER BLADES
Feb 11, 2015 | Honda Garden
Cub cadet:position of blades on mower deck of a cub lt 1045
the easiest is to lift it of ground a little.... not started and position the blades parallel to the body of the tractor. The blades even misaligned should not hit each other or cause any issues. with the blades disengaged they should move freely or with minimal effort
Sep 27, 2014 | Garden
What is the easiest way to change the blades on my yth23v48 rider
Blade removal instructions on page 15 of your manual state the best, conventional way (without removing the entire deck).
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_NAen/HUSO2011_NAen_YTH23V48_532438710.pdf
Sep 13, 2011 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
I would like to know the best way to change the blades on a42in lawn tractor it has 2 blades thanks
The very best and easiest way to remove the blades is with an air impact wrench. With an impact wrench it is simple as you do not even have to hold the blade, but with a ratchet and socket you must hold the blade while trying to remove the bolt. Use a piece of wood to wedge the blade so it cannot move.
Apr 24, 2010 | Garden
How do I undo the bolts holding the blades on my Masport 400 mower? When I try the disc holding the blades just keeps rotating.
The easiest way is with an impact wrench. If you don't have one there is usually a hole in the disc where you can insert a screw driver to lock it from turning.
Dec 02, 2009 | Black & Decker Lawn Mower Replacement...
The belt slipped off the lawnboy self propel. what's easiest way to put it back on?It slipped off at the rear of the mower and i can't get to it. would it be easier to take the blade off and do it that...
The blade is usually easy to take off, and it will give you some room to work. There should also be a removable cover over where the other pulley is you can remove.
If the blade is old, take this opportunity to replace it.
Nov 20, 2009 | Garden
Ariens ezr1742 mower blades do not engage....noticed after went over a stump.
The common cause of this problem is that one of the safty switches has come dis-connected or has failed since most every newer mower has a electric clutch controlling the mower deck PTO there are safties bilt in under the seat and in other locations to make sure everything is ok before the blades engage, easiest way to test this is to run a jumper from the positive post of the battery to the input wire on the electric clutch assembly making sure all other wires ade dis-connected from the clutch and see if the blades engage if so then usint a continuity tester check all the wires and switches to this item to check for a faulty switch or broken wire. Thanks Don
Nov 09, 2009 | Ariens 34 In. Zoom Series Riding Mower
Hi, I have a westwood ride on mower & the 3 bladed 36inch deck has started to whine bearings I think? Are they easy to change? special tools? parts off who? the machine is just 3 years old Thanks JT
I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
Sep 20, 2009 | Garden
Changing blades on riding mower
Must be able to get to underneath side of deck obviously. If you do not have access to impact tools, it is usually easiest to remove the deck as you must keep the blades from turning. Place a block of wood to where it will jam the blade while attempting to turn the nut. (7/8" socket or wrench). Usually very tight, try some penetrating oil to help.
May 18, 2009 | Garden
John Deere Replacement Hydrostatic Transmission Lt150, Lt160, Lt170, Lt180 Logo
148 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
