Question about Pioneer Car Audio & Video
Manuel pioneer avh-200bt radio troubleshooting wiring
Radio wont come on
bestdarngood
  • 3037 Answers
SOURCE: Pioneer avh p4000dvd w/GMOS-04 wiring harness
I think you need a different harness, this one isn't handling the power I believe. What are the wire gauges
Posted on Jun 05, 2008
SOURCE: how to instal my pioneer avh-p57000dvd
you have to run a toggle switch to do it connect the part where it runs from the dvd player to the main connector on the toggle then find a ground and connect that to the ground on the toggle and flip the switch put a dvd in and should work
Posted on Aug 15, 2008
ward_knutson
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Posted on Mar 25, 2009
  • 24 Answers
SOURCE: i cant find a wiring diagram to install my new
Operation and Installation Manual: http://akamaipix.crutchfield.com/Manuals/130/130AVHP400.PDF
Posted on Sep 17, 2009
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
I HAVE A PIONEER AVH-P5100DVD AFTER CONNECTING ALL WIRES THE UNIT WILL NOT POWER ON. IM INSTALLING IT IN A JEEP CHEROKEE.
make sure u have connected the fm tunner silver box if not thats your problem if u do not connect it it wont power thats really important.
Jul 01, 2009 | Pioneer AVH-P5000D Car DVD Player
Bypass without switch
Get a relay (4 or 5 pin) from Autozone, O-Reilly, PEP Boys, etc....
Connect wires as follows on relay:
Pin #86 - Amp remote from your radio (blue wire)
Pin #30 and #85 - to a chassis ground (metal dash bracket)
Pin #87 - to Parking brake input wire on your radio (light green)
Pin # 87a - IGNORE. It isn't used in this case.
What this will do is.....
Radio will power on when you turn your key. The amp wire is delayed slightly and will trigger the relay in a second or two. This tricks the radio into thinking your e-brake has been engaged and violla....Mine has worked everyday since I connected it.
Apr 07, 2009 | Pioneer AVH-P4000DVD Monitor
AVH-P6600DVD
You have it wired wrong. The red wire goes to the key switch and the yellow wire goes to the battery or a constant hot wire.
Good Luck and please rate
Jan 22, 2009 | Pioneer AVH-P6600DVD Car DVD Player
Pioneer AVH-P5700 instalation
Sep 10, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-P6000DVD
You cut the green brake wire leading to the brake and get a single pole switch from radio shack wire the green to the power part of the switch and get another piece of wire and ground it some where. when you want to play when driving click the switch and it will play while driving.
May 30, 2008 | Pioneer AVH-5700DVD Car DVD Player
Car Audio & Video Logo
57 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
