Question about BaByliss Babyblisspro Ceramix Xtreme Professional Curling Iron
How do I take a babybliss pro curling iron apart to check the connetions because when the shaft is turned it loses power, but if you wiggle the cord at the end of the shaftthen it will at .
At times go on or off
Where can I get a spare spring for the arm of my curling Iron? I live in South Africa
no where unless from the manufacturer.they usually are made as a throw away item
Sep 01, 2016 | Conair BaByliss Pro Spring Curling Iron
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
Urgent!!! How do i replace power cord on babybliss pro tt hair straightener
It is not a good idea to replace cords on those unless u take it ap apart and resoder it to tha board
Jul 14, 2016 | BaByliss Pro TT Tourmaline Flat Iron /...
How do I turn the silly thing OFF?
If the power switch does not trigger to cut off the power all you need is to attach the heater to an power extension cord with a power switch to turn it off. The other option is to open the unit to check on the switch and the trigger to the circuit.
Dec 26, 2013 | John Frieda JFC8 CURLING IRON
Curling iron power cord replacement
Simply get a cord of the same amperage and voltage, strip both cords, splice them, tape them well and you should be good. Keep fido away from the unit, lest he become a corn dog!
Aug 19, 2017 | instyle.com Computers & Internet
Just stop working. seems as if no electric power is reaching wherever it is suppose to. Iron is about 2 years old.
Those types of problems are usually one of two things... the cord where is enters the iron, the wires are broken. Or the thermostat has gone bad...
The iron will need to be taken apart and the wiring checked witha meter to find the problem for sure...
heatman101
Sep 27, 2011 | Euro-Pro Shark GI490 Iron
Adapter problem? Or is it the LCD?
The charging problem could be the charger itself or the adapter. To check the adapter wiggle the pin to see if its loose. If its firm it could have a dry joint.
With the power supply you wil have to check the voltage output with a multimeter. The voltage will printed on the black box thats connected to the wires. If the meter registers nothing you will need to possition the wire (curl) the way you used to to check it again. If the power supply voltage registers then its the power supply that has to be changed.
As for the screen going dark that means the backlight is out. This means you will have to remove the inverter (power supply for the backlight). The inverter is located at the bottom of the screen behind the screen bezel (plastic surround) On the inverter there will be a coil with copper wires wound round it. Get a soldering iron and re-solder the points around the coil then reconnect it to see if it works. In 90% of cases this brings the inverter back to life and your screen lights up. The other 10% the inverter or backlight has failed and needs to be replaced.
In all cases this could mean taking the laptop apart and can be quite difficult if you're not savvy with a soldering iron, so my advice would be to either have a friend help you has experience in taking things apart and who can use a soldering iron, or have the laptop serviced by a reputable PC repair store.
Please post back if need anymore advice.
Regards.
Feb 07, 2010 | Dell Inspiron 1525 Laptop
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
BaByliss Babyblisspro Ceramix Xtreme Professional Curling Iron Logo
542 people viewed this question
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
