Fridgidaire front load washer..control lock won't shut off
My washer is a Frigidaire front loading one...FTF2140ES1, purchased Jan 2005. It will not run. I can see that somehow the "control lock" safety feature has been initiated . I assume someone locked the controls by pressing the "options" and "select" buttons at the same time. (or so my manual says) However it tells me to unlock the control lock by pressing "options" and "select" simultaneously...it's not working..."beep beep beep" is all I get.
We are getting dirtier and stinkier by the second! Any advice?
I spent two days freaking out about this same problem.
I almost went out and bought a new machine because repair technician would cost so much...
The solution of pressing option and select at the same time didn't work right away...but after 2 minutes ... it did !!!!!!!!!!
Awesome. Thank you thank you to the person who posted that solution!! It actually worked!
Posted on May 28, 2009
Followed the advice given in Solution #1 and after a few times, it worked! Thanks!
Posted on Dec 28, 2007
I have had the same problem before and all I did was hit the option and select and it worked. I had to do it a few times to get it to work.
Posted on Nov 25, 2007
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
My affinity fridgidaire wont complete a full cycle, it wont spin the clothes, it just stops. Help?
That would ether be your door lock or motor control board would need more info from you to pinpoint/bye for now...
Jan 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire front loading washer
Open the bottom and check to see if the shocks are good.
Apr 09, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dryer door problem
Most likely the door lock is bad, check the wire connections to make sure thay are connected. If so replace the door lock assembly.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
303 people viewed this question
Top Washing Machines Experts
