Question about Cameras
How do i get a camera to flash because mine is not working so how do i get it to work
    Top Expert:
  • Cameras Master
  • 50,567 Answers
Flash units use a considerable amount of power at each flash so check that you have the correct batteries ( rechargeable only) installed and that the charge level is high enough to fire the flash
If that is all covered ,take it to a camera shop and get advice as to the problem
Posted on Apr 08, 2015
The flash on my Sony dsc f828 does not work
Hi, mine was doing the same, no flash, after I dropped. I reset it with the little hole next to where the memory goes and it worked!
good luck!
Mar 27, 2012 | Sony Cyber-Shot DSC-F828 Digital Camera
Have a samsung camera that seems to be frozen. The lens is open but there is nothing on the screen. When pushing the power button the power light flashes, the camera makes a beep and the the power light...
Hi, this happened to my Samsung ST500, it took me months to find out what was wrong with it!, i found out the it gets stuck when the lens is different or has dirt in the lens.
  • I Got Mine working by cleaning the lens but if that dosnt work try this, mine started working when i dropped my camera quite high onto the ground which can make your lens pop back in if this dosnt work, try your warranty!:)
Oct 24, 2010 | Samsung DualView TL220 Digital Camera
Canon d60 - Built-in flash will not pop up
There may be something obstructing it from popping open. Inspect the flash area carefully. You could remove the battery and put it back in to see if it corrects the problem. Also, check the flash settings in the menu to make sure that the flash is set to operate. If all of those fail then take the camera in for warranty repair. If the warranty has expired and nothing else works I would suggest getting an external flash for you camera. You will be amazed how much better your photos come out using an external flash. If you go that route then I would suggest going to a camera shop or department to make sure the flash will work for you before purchasing. If you just want a small flash a little better than the built-in, get the SB400. It's only around $125. The SB600 is much better, but will cost almost twice as much (but I think it's worth it).
They work beautifully in auto, but the SB600 will reach much farther and give you less red eye. Good Luck you have a great camera!
Nov 10, 2009 | Canon PowerShot EOS D60 Digital Camera
Flash doesn't work on nikon coolpix l12
I actually just fooled around with mine because it was doing the same thing. It will only flash in the scene mode, but not the normal quickshot mode. i noticed under the camera symbol on the screen said BSS and i went into the menu and clicked on BSS and turned it off b/c it was on and that worked finally.maybe u can try it, if its the same situation.
Jul 20, 2009 | Nikon COOLPIX L12 Digital Camera
Quantaray QDC 900WA no longer works on Camera Hot shoe
tengo un flash QDC 900WA PERO COMO HAGO PARA QUE TRABAJE ESTAVA TIENE FUNCION ESLAVA EL FLASH O TENGO QUE COMPRAR LA UNIDAD ESLAVA APARTE
Aug 06, 2008 | Quantaray QDC-900WA TTL Flash
Sony DSC-T200
Try initialising the camera (settings menu) - the flash options came back on mine, and the flash worked again.
Jul 09, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
May 03, 2008 | Sony Cybershot DSC-H3 Digital Camera
Flash stopped working after 1 month
I had the exact same problem,on the back of the camera there is a 3 position slide switch make sure its in the position that works with flash mine is in the middle spot I think the switch is/was a bit dicky try playing with the switch a bit,anyway mine now works 100%.Try it anyway.John Leigh.
Apr 15, 2008 | Nikon COOLPIX L10 Digital Camera
Flash Settings Only Work When in Night Mode
Hope this helps it got mine working
leave lens cap on in night mode then start up flash & take a shot,
press the flash key symbol button & you should see changes on the screen monitor, then go to auto mode to take a shot with flash make sure AF is not on.
Sorry it is a bit vague but this got mine working again.
Dec 13, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Cameras Logo
283 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
