Question about Lands Phones
AEG chamfer 215 - 3 -- the base answering machine is on, but won't record messages. It's not full. How to reactivate it to record incoming call messages, please? Thank you.
  • 72 Answers
SOURCE: change message
press menu on the base.
use the volume up and down buttons to change to the answ. setup
go to greeting and follow the menu prompts to record a new greeting, then select change to pick which outgoing greeting is played.
you can download a manual from:
http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Oct 23, 2007
  • 3 Answers
SOURCE: Recording messages
Manual is online:
http://www.fixya.com/support/p129719-ge_29869ge2_digital_answering_machine/manual-13322/page-3
A warning I'll pass on that I just learned:
I just lost 57 special messages that I had saved for years to follow up on, and learned the hard way (if you haven't come across it yet):
From page 6 of manual:
INSTRUCTIONS FOR MOVING THE ANSWERER...
3. Go to the electrical outlet and unplug the power supply. DO NOT UNPLUG THE POWER JACK CONNECTED TO THE UNIT. If you do, all memory will be erased.
I wasn't even moving it to another place, the jack just came a little loose while moving it around the table, and all the messages disappeared. A very poor detail in an otherwise (in my experience) well-designed machine. Manual's page 6 covers this: http://www.fixya.com/support/p129719-ge_29869ge2_digital_answering_machine/manual-13322/page-6
Posted on Sep 01, 2008
richa33
  • 71 Answers
SOURCE: AT&T Answering Machine Model 1717
It maybe hardware issue. Make sure the recording DTAM chip is working. You can try to record your personal annoucement, to see if the chip still record message.
Posted on Jan 21, 2009
SOURCE: AT&T E5965C phone answering machine does not record incoming mess
My E5965C dosenot record in comi8ng messages.
Posted on Jul 10, 2009
  • 80 Answers
SOURCE: when ever the call comes, the answering machine
The digital memory is full according to the error.
You will have to remove some old messages.
If this is not the case try unplugging it from the power source for 30 minutes then plugging it back in to clear the error.
Posted on Oct 12, 2009
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
heard.
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
messages".
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
How to get a dial tone on AEG Chamfer 215-2?
If it was a lightning strike and had a power surge that toasted it you could contact your utility company about a claim.
Oct 28, 2014 | Lands Phones
How dow i unlock an aeg chamfer 210 cordless phone
DOWNLOADS VOXTEL D210 COMBO MANUAL
If this is not what you have, please provide a complete serial number, so that the best answer to your question can be provided.
Jun 21, 2014 | Uniden Cordless Phone
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
. Base unit Answer on
Lighted button you see may not be for ANSWER SYSTEM. Lights on Base units may indicate INCOMING MESSAGE already stored or all sorts of system ready lights.
Please do these three steps:
1. From the handset, Go to menu and set ANSWER system to ON once more
2. In the menu, set the number of incoming rings before ANSWER system turns on, to just 2.
3. In the menu, record a new message using your own voice.
then, Dial your own phone number from a cell phone to test.
Watch/listen as the incoming message is played. repeat any of the above if the system doesn't work.
Post a new question and include the model number and manufacturer of your system.
I work for a manufacturer of these machines and I can help.
S
Feb 22, 2011 | Cell Phones
Base shows an A instead of 0 for mailbox.
You have your answering machine set to the announce mode, where it plays an outgoing announcement but does not record incoming messages. You need to switch it to the record mode. Since you declined to specify the model of your AT&T 5.8GHz system, I can't tell you how to do that. Please refer to the manual for instructions.
Oct 27, 2010 | AT&T 5.8GHz Cordless Phone System with...
Says machine is full, but there are no messages on the machine
make sure you retrieve all messages . I mean you may have 0 new messages, but you have lots of old messages ,it may full too.
Otherwise, delete all message, try to record incoming message or record your personal greating. Make sure the record function work, record chip works as well.
Jan 15, 2009 | GE 29875GE Digital Answering Machine
Lands Phones Logo
117 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
