Question about Car Audio & Video
What is L R on my amplifier - Car Audio & Video
  • 2,039 Answers
L for left side r for right side
Posted on Apr 08, 2015
Is teac avr 21g a power amplifier or just an amplifier
I think you are getting confused between an amplifier and a pre-amplifier.
The AVR 21g is an amplifier, which will have a pre-amplifier built into it.
A power amplifier is an amplifier. It has the ability to drive speakers. However one on it's own, you can't connect tape decks, record players or any device you want to listen to.
A pre-amplifier doesn't have the ability to drive speakers. But you can connect devices to it.
As the device you are asking about is a audio video receiver (AVR) then it will have both amps in it.
Some of this type even have the ability to have both amps separate.
May 31, 2018 | Teac Audio Players & Recorders
Tip
Dish Network Stereo Receiver Remote Codes
This is the From the Dish Network website. http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml You can also call them for information on your set-up at : New customers call: 1.888.825.2557. Current customers call: 1-888-686-2388. CODE Aiwa Amplifiers 636, 641, 656, 687, 718, 720, 774, 775, 726 Bose Amplifiers 761 Carver Amplifiers 653 Citizen Amplifiers 709 Curtis Mathes Amplifiers 734 Denon Amplifiers 647, 674, 757, 758, 759, 760, 762 Fisher Amplifiers 653, 741 GE Amplifiers 711 Goldstar Amplifiers 677, 69 Harmon / Kardon Amplifiers 640, 672, 751 Hitachi Amplifiers 717, 754 JBL Amplifiers 640 JVC Amplifiers 637, 683, 703, 725 Kenwood Amplifiers 649, 676, 691, 726, 728, 745 Luxman Amplifiers 752 Magnavox Amplifiers 654, 705, 740 Marantz Amplifiers 651, 740, 742, 743, 764 NAD Amplifiers 739 Nakamichi Amplifiers 671, 748, 750 NEC Amplifiers 716, 739 Onkyo Amplifiers 642, 660, 662, 678 Optimus Amplifiers 648, 664, 734, 744, 749 Panasonic Amplifiers 643, 644, 652, 742, 746 Pioneer Amplifiers 658, 667, 668, 679, 702, 734 Proton Amplifiers 654, 705 Quasar Amplifiers 652, 742, 746 Radio Shack Amplifiers 744 RCA Amplifiers 635, 638, 704, 727 Sansui Amplifiers 753 Sanyo Amplifiers 741 Sharp Amplifiers 712, 713, 714, 715, 749 Sherwood Amplifiers 646, 670, 736, 738, 744 Sony Amplifiers 639, 645, 650, 687, 728, 728, 730 Soundmatters Amplifiers 763 Teac Amplifiers 684, 737 Technics Amplifiers 643, 644, 652, 742, 746 Toshiba Amplifiers 710 Yamaha Amplifiers 663, 730, 731, 732, 733, 745, 747
on Jun 06, 2009 | Toshiba XB1507 Receiver
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
Why won't my MA120 fast act amplifier turn on?
A pre-amplifier allows a range of components with different output levels to connect to an amplifier. Usually one is used to allow a low-level magnetic phono cartridge to be used with the line-level input of an amplifier. These used to be separate units; now integrated amplifiers combine control function with amplifying low-level signals. They also provide tone, volume and balance control.
Jul 04, 2014 | Audio Players & Recorders
Not powering on
To troubleshoot amplifiers when it's not starting up
check the base to base voltage of driver transistors might be too high.
Make sure that the amplifier's ground wire is tightly attached. If it doesn't look too good then take it out and clean it. Use a metal brush to clean that area.
Low power may cause your amplifier not to turn on. Make use of voltmeters to check if your amplifier is getting the right amount of power for it to work. Amplifiers need 110 volts or less to function if the power coming in does not reach that it means you have la defective power cable. If the power is alright and it reaches a minimum of 110 volts, and your amplifier still doesn't turn on that means that there is a problem with its power supply. Checking an inline fuse helps you to determine the appropriate amp ratings when you troubleshoot amplifiers. This is the best way to troubleshoot amplifiers with power problems.
To troubleshoot amplifiers that seems to be on standby mode
Look into your input sensitivity. An input control allows you to match output voltage that is coming from the main unit going to the amplifier then to the stereo speaker. The amplifier shuts down if the gains are
adjusted too high. This is simply because it overheats when it is set too high thus it automatically shuts off. When you troubleshoot amplifiers and this happens you will notice that the volume gets lower even if the setting is too high. Be aware of the optimal levels of the components when you troubleshoot amplifiers.
Your speaker's electrical impedance may also contribute as to why your amplifier may be turned on but doesn't seem to work. Impedance is the amount of current which flows with a specific voltage throughout the transistors, capacitors, etc. Just see to it that your amplifier and speakers equal in impedance range when you troubleshoot amplifiers. Use the voltmeter to check the impedance range when you troubleshoot amplifiers.
Take care..
Sep 14, 2011 | Audio Players & Recorders
Every time i hook up my coustic car amp the radio will turn on with out the radio on
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RADIO OR AMPLIFIER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL POWERS UP ON ITS OWN, THEN REMOVE THE REMOTE TERMINAL COMING FROM THE RADIO. IF THE AMPLIFIER SHUTS OFF, THEN YOU MAY HAVE A SHORTED TURN-ON TRANSISTOR WITHIN THE RADIO AND IT IS OUTPUTTING THE DC NEEDED TO TURN THE AMPLIFIER ON. IF YOU REMOVE THE REMOTE TURN-ON FROM THE RADIO TO THE AMPLIFIER AND THE AMPLIFIER STAYS ON, THEN THIS POINTS TO A FAULT WITHIN THE AMPLIFIER AND IT WILL NEED TO BE SERVICED. MAKES SURE THAT THE AMPLIFIER AND RADIO GROUNDS ARE 100%. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 15, 2010 | Coustic Car Audio 401SE Car Audio...
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
How do I use this amplifier to amplify an ipod?
minimize ur ipod volume to the lowest & disable bass boost or lower the bass in the ipod,control vol by the amps knobs,play higher kbps songs on amp
Jul 09, 2009 | Alesis RA-150 Amplifier
Need user manual for setup of the amplifier.
It should say next to the speaker terminals what impedance of speaker the amplifier is rated for. You can drive any speaker within reason with just about any amplifier as long as you are not trying to attain loud levels. Here is a link to the service manual for your amplfier. It states in the schematic power ratings for 2,4, and 8 ohm speakers so you can assume that this amplifier is compatible with those impedance speakers. NAD is generally known for their beefy amplifier sections. http://www.scribd.com/doc/7234868/NAD-3020-Service-Manual
May 03, 2009 | NAD C325BEE Amplifier
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
May 25, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
