Braemer heater fault code -11 what does that mean
2 Suggested Answers
  • 120 Answers
SOURCE: Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Posted on Jul 21, 2010
Braeme HX OT2 open at start (fault 19) how to fix
says I should change the HX OT1 and HX OT2 switches and reset in service mode, however can't find where to get these
Jul 30, 2013 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Code 11 come out from the led. The heater rinnai 556FTR doesnt work at all. Code no 11 is blinking. Thank you
A couple of things can cause a Code 11(Ignition Failure): The gas line at the heater is not turned On or not turned on all the way. Also an obstruction in the Direct Vent Termination.
According to the Owner's Manual:
If the appliance fails to ignite, the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. If ignition fails again, then the fault code will remain and another attempt to ignite will occur in 1 hour. The fault code is not stored in the fault code history.
If the flame is extinguished during forced combustion then the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. Forced combustion takes place for about 15 seconds after ignition. After this time, the temperature control logic controls the combustion.
If the flame is extinguished (burner combustion failure) while the temperature control logic is operating the appliance, then the appliance will immediately attempt ignition. No fault code will appear.
If the problem was not either of the 2 listed above, the electronics may need to be reset. You can do this by turning the Master ON/OFF Switch to OFF and unplug the cord from the wall outlet. Leave the unit unplugged for 15 minutes, then plug it back in and turn the Master ON/OFF Switch to ON. The electronics should revert back to the original factory settings. From there you can set them as you like. If the reset attempt fails, a service call by an authorized service technician is the next step.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 31, 2011 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Fault code 11 flashing started when the meter was replaced outside don't have a manual to tell what it is
Apparently, when they installed the new gas meter, they didn't purge all the air out of the gas line to your heater. So gas is not getting to the heater. Fault Code 11 is an Ignition Failure.
To help you even more, I am providing a link to your Owners Manual that you can download and print for future reference. http://www.rinnai.us/documentation/downloads/ES38_1004RFA_Manual.pd
Hope this helped to solve your problem. Please be kind enough to let me know.
Mar 10, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
A11 Fault
A 11 is a heater problem. It is given a certain amount of time to reach the proper temp then the fault code A 11 comes on. The heat element may not be working. If you select no heat (if available) it may not show the fault.
Apr 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Braemer Spectrolink ducted heating - heat won't turn on
MY GAS FURINACE IS LOCKOUT WHAT IS SOLUTION
Mar 23, 2010 | Heating & Cooling
Code 11 on Rinnai Avenger 25 gas heater
11 means no gas / failed to ignite - check the bayonet is fully plugged in properly, they can be hard to plug/unlpug - otherwise you wilol have to take it in for service.
Aug 19, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Heater won't start error code 11
I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
Jun 15, 2008 | Rinnai Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
