Question about Refrigerators
Need the nylon door closer that is mounted on top of the door
  • Brad Brown Apr 08, 2015
    Hi Robert Brewer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
Its called a gasket and with no info,make model,etcetcetc,we cant help you
Posted on Apr 08, 2015
    Top Expert:
  • 12,962 Answers
Go to appliancepartspros.com with the model number and the exploded diagrams will tell you exactly the part you need and the cost.
Are gate closers really effective & how it works?
Gate closer is a device, which consist of steel spring in a spiral shape fix on the door that close the door automatically without any human being intervention or electricity. http://www.gateshut.net/about-gate-closer.html
Jul 24, 2013 | Rixson Exterior Gate Closer With Sliding...
I have a maytag model # MTB2195AEW when I moved they had to remove the doors now the doors are not fitting properly. The light is staying on inside.
Check to make sure there is a nylon washer between the bottom of the doors and the hinge. Also, the hinge mounting screws generally can be loosened, the door shifted a bit, then re-tighten the screws to adjust the fit of the door.
Jan 12, 2010 | Maytag MTB2195AE Top Freezer Refrigerator
The power window motor is dead. I purchase a used/new one at Rockauto. This is a 2003 Nissan Murano, I took the door panel off and replaced the motor. However in doing so the window fell int othe door. How...
first you''ll need to get it back on track if it's off now and get it, closer to the closed position to verify that it is actually fitting properly, then you'll need to use the power switch to raise the mounts to where they are at the same level as the nylon glass mounts to install the 2 bolts you removed, or, lower the glass, while in the track it glides in, to the point where you can install those 2 bolts. The glass may just slide upward from where it is & then you put the bolts in or you may need to tilt & turn it carefully until you can get it back on track.
Best I can do from here,
good luck.
Jan 01, 2010 | 2006 Nissan Murano
Not enough clearance from rafters to install the
Here is the information I think you need.
There is an accessory available from Sears and some home stores called a "low clearance bracket kit". It can be used on any sectional garage door that has clearance problems due to low ceilings or obstructions, allowing the garage door opener track to be mounted much closer to the top of the garage door than is usually possible.
The top guides (which hold the uppermost garage door rollers) on your door are replaced with specially designed brackets that cause the top of the top panel of the door to move inward further as the door opens than standard top guides. The result is that the top of the panel does not rise as high as the door opens, giving the additional ceiling clearance.
I have a photo of this item on this page: http://www.naturalhandyman.com/iip/infgar/infgar1f.html
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a whirlpool gold side by side that makes aloud popping noise when opening and closing right door
Sounds like the door closer is bad or screw loose . Remove the top hinge cover and the 3 screws holding the hinge . Remove the food from the door first . After removing the 3 bolts , lift the door from the bottom hinge . You can tell by looking , if closers need replaced or if the screw needs tightening . If closers need replaced , both come in 1 package ( 1 for the door and 1 for the bottom hinge .)
Aug 09, 2009 | Whirlpool Refrigerators
SubZero 532 (1994: Top of refrigerator just inside the frig door
u have older 532 - the external cam gets stuck and the door's hinge pin snaps - there is just enough of it left so the door stays inside the body's hinge bracket's hole, and the washer is gone - u need the lower RH door hinge pin with nylon washer - it attaches to the bottom face of door and the pin goes downward into the closer which mounts to the body at an angle - the much newer ones have the cam pieces that everyone's talking about download www.subzerolosangeles.com/partsview/532-1.pdf
u need parts 0180271 rh door closer, and 3540420 door hinge w/pin bottom RH -- part on page 4-24 picture on pg 4-25 use the picture title "prior to serial no. M824xxxxxx
May 07, 2009 | Refrigerators
Top of refrigerator just inside the fridge door has condensate collecting and eventually dripping onto the floor. I "inherited" this fridge from previous tenant who SWEARS that it is was caused by a...
If the door pops open after you close it, or the door is hard to push closed, the door closing mechanism has probably failed. Make sure you check for the obvious things, such as something sticking out of one of the shelves or orange juice cans rolling around the door shelf area causing the door to bounce back open when the door is slammed.
If you notice any unusual sounds when the door is opening and closing, such as a clicking or grinding sound, your door closer is probably worn.
There are three common types of door closers used in domestic refrigerators and freezers. We list here all three, along with how to access each component in order to change it.
The most common door closers used today are small plastic cams mounted at the bottom of the refrigerator and freezer doors. When you open the door, you cause the door to climb up onto the lower cam. When the door is released, the incline helps the door shut. To view a common door cam kit, <a href=" http://www.repairclinic.com/0081.asp?RccPartID=1035 ">click here</a>. You can see how the upper and lower cams each have a hill and valley that work against each other to make the system work.
In order to change these, remove all food in the door, and remove the upper hinge in order to take the door off. Most hinges have a plastic cover that can be removed by prying up on it to expose the upper hinge screws. Usually, the cams mount with one screw -- one on the bottom hinge and the other on the outer door panel. On some models, the lower cam is riveted onto the lower hinge, and it's easier to purchase the lower hinge complete rather than try to drill out the old rivet.
If the cams you are replacing are for the freezer door that has a water line going through the middle of the cam, you not only have to remove the door but you must also disconnect the water line. Most water lines are fed through a channel in the door panel and clamped into place in the dispenser housing. Or, there may be a quick disconnect fitting behind the kick plate or apron on the unit. Once you've installed the new cams, you may want to put a light coating of lithium or silicone grease on the surfaces where the cams meet.
Another type of door closer is actually part of the upper hinge assembly itself. To view this style of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=781123 ">click here</a>.
In order to change this style, pop off the hinge cover, and remove the screws that retain the upper hinge. From there, pry up on the hinge and pull it through the hole in the outer door panel. If the spring is broken and will not come through the hole, remove the inner door panel. This is a big job so you might want to remove the door and lay it on a flat surface. Fold back the door gasket and remove all the screws around the perimeter of the door until you can separate the inner door from the outer door to gain access to the hinge assembly.
A third type of door closer commonly used is one that is internally mounted to the outer door panel, and you must separate the inner and outer door panel to gain access to the closer. To view this type of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=616347 ">click here</a>. In this style, the hinge pin actually goes through the closer. The hinge pin has a flat spot on each side of it that meshes with the cams on the closer. To view this style of hinge pin <a href=" http://www.repairclinic.com/0081.asp?RccPartID=641650">click here</a>. On some Sub Zero units, this closer is mounted to the lower portion of the door and removal of the inner door panel is not necessary.
May 05, 2009 | Refrigerators
My 2001 Dodge Durango window will not go up or down.
Sounds like the ball link for the window regulator broke. You will need to remove the door panel for a closer inspection. Most auto parts stores have the replacment parts
Mar 21, 2009 | 2001 Dodge Durango
Side by side jenn aire refrigertor. After six months of use, the right door blows open when closing the left door. I have re leveled to no avail. Any suggestions on the problems
That's not uncommon, but the door should swing back shut. The fridge should be level side to side, but tipped back just a little. This will help the doors close. Also some fridges have door closers on the door hinges. They are usually plastic or nylon and can wear flat. If your fridge has these, the doors will lift just a little (maybe 1/16th to 1/8th inch) when it's opened. Usually the fresh food door is bigger and heavier and will wear out closers faster than the freezer door.
Jul 21, 2008 | Refrigerators
GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Oct 22, 2007 | GE WDSR2080D Top Load Washer
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
