Question about Fusion Car Audio & Video
What would you recommend for best location to run my remote wire for the amp In a 2013 Fusion with MFT
2 Suggested Answers
SOURCE: 10 inch fusion amp
first of all your question is unclear, do you need speaker advise or amplifier advise
Posted on Feb 23, 2008
Need stereo wiring diagram for a 2013 ford fusion
If you found this please email me djnergy@yahoo.comI need to know wires for 2013 Ford Fusion
Jan 20, 2013 | Car Audio & Video
How to hook up the wiring on the crunch 520.5 need to know the gage for power
  • I would go with some good 8 gauge. More than that for this amp would be overkill and a waste. Many people thing thicker wire is better but that is not the case. To thick of wire to the power feed can draw to much power and send the amp into protect mode. Also to thick of wire with an insufficient amount of power can actual hamper the amps true abilities.
  • Use stranded copper wire not solid copper wire for the best results of conductivity.
  • Make sure to run a 50 amp fuse inline with the power wire right off the battery. Amps surge and it is far easier to replace a $1 fuse than components inside your amp.
  • Your ground is best served running to a bolt in the floorboard. Using the same size, style and quality as your power wire is recommended.
  • Your remote wire will connect to the remote wire running from the back of your deck. The remote wire enables your amp to shut off when your deck is shut off. A simple 16 gauge stranded copper wire will suffice for the remote wire.
  • I recommend hooking the speakers up using one speaker per channel. I don't bridge amps really. If you want more power then buy a bigger amp.
  • The AV cords will go from your deck to your amp right to right and left to left.
  • That's the way to wire your amp.
Regards, Tony
Apr 22, 2011 | Crunch P520.5 Car Audio Amplifier
Power problem
The best places to look are:
1. Remote wire running from fuse box or back of head unit.
2. Ground wire, make sure it is connected good the the body of your vehicle. (I almost threw away and $700 amp because the ground wasn't secure enough).
3. If equipped, inline fuses on power wire or connections on battery.
If all these check out, then its probably a short inside the amp. You can have them fixed, but sometimes it cost just as much for a new one! Hope this helps and good luck!
Jul 11, 2010 | Fusion ENAM60040 Car Amp
Fusion amp soild bold red when the radio comes on
The amplifier is in protection mode.
3 reasons for this...
  1. Improper Load/overheat - wrong impedence voicecoils or wired improperly below rated impedence.
  2. Grounded Power - speaker wires touching, power wire touching ground,
  3. Internal component failure.
if the amplifier will still not go out of protect mode after removing the speakers and jumpering the remote wire to the + terminal - your amplifier needs professional repair.
Thanks for using FixYa - a good rating is appreciated for taking the time to answer your FREE question.
Jul 08, 2009 | Fusion Digital designs EN-AM6004 Car Amp
I have a 2channell FE-402 fusion amp,with a fusion sub,and a set of vibe k-series 69's that have a max power of 525 watts. I tryed wiring the sub with the speakers and the speakers sound fine but the sub...
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Jun 06, 2009 | Kicker KX500.2 Car Audio Amplifier
Amp turns off
Sounds like remote turn on wire is bad. If using aftermarket HU, find another location to power amp. Try the the power antenna wire on the HU to run the REM.
Jan 24, 2009 | Pyle PLAM1200 2-Channel Car Amp
Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Dec 09, 2008 | Fusion FEW12PK Car Subwoofer
I have two fusion amplifiers in my car.When i turn on my cd player one turn's on and another one not.What's a problem?
Make sure your power is properly connected and grounded on the amp that is not powering on.
The remote (blue) wire from each amp has to be connected to the remote wire or remote location on the deck itself.
You can also bridge the remotes from both amps to each other as long as the remote is connected from one of the amps to the remote location on the deck.
Aug 19, 2008 | Car Audio & Video
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
Car Audio & Video Logo
Top Fusion Car Audio & Video Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
