Question about Garden
I need the lever that controls the opening of the feed gate. The only number on the spreader is 0195 ther is no explanation for this number
It has an olive green rectulanger fiber glass hopper. Holds about 50 lbs. Spreader is five or more years old
    Top Expert:
  • Garden Master
  • 42,108 Answers
I would take the machine to a lawn mower shop and get advice as to what make it is and if there are any generic levers that could be adapted to do the job.
Posted on Apr 08, 2015
My Scotts Deluxe Edgeguard has broken. The cable that pulls the fertilizer feed door open (when you suqeeze the lever) has sheared off where the cable meets the body. Is there some way to obtain the p
Try calling their helpline here.
Scotts Help Center experts are available toll-free at 1-888-270-3714
They will often send you small parts at no charge.
Oct 05, 2014 | Scotts 1237443 74434 Deluxe Edgeguard...
I need parts for scotts precision flow model pf1
My Scotts Deluxe Edgeguard has broken. The cable that pulls the fertilizer feed door open (when you sqeeze the lever) has sheared off where the cable meets the body. Is there some way to obtain the part(s) I need? What about a repair manual so I can figure out what part(s) are required?
Jun 08, 2014 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
I want to retrofit my moultrie atv spreader manual feed gate with an electric feed gate. They did not offer the electric feed gate when I purchased my current model. Both models are identical except for...
I am also looking to retro fit my manual gate spreader with the electric gate. I emailed Moultrie with the question about it and they emailed back about two weeks later that I needed to contact customer support. I call customer support but hung up after being on hold for 15 minutes. I have not found the electric gate anywhere else so I guess I will have to call them back. At this point it appears that is the only way to get one. I have been told the retro fit works with no problem.
Moultrie Customer service: 1-800-653-3334
Jan 14, 2013 | Moultrie ATV Spreader With Electric...
How do i calibrate the spreader
Your AccuGreen 3000 Drop Spreader was calibrated at the factory. However, a spreader's calibration may change or slip over time or during periods of heavy use.
You may check the calibration of your Scotts Accugreen 3000 by first adjusting your micrometer setting to 6. Turn the spreader over so that you are looking at the outside of the bottom of the hopper. Use your foot to hold down the trigger (if your trigger has a locking mechanism you can lock it in place prior to turning upside down). With the micrometer set at 6 and the trigger squeezed against the handle, the front edge of the projecting ridge on the shut-off bar should be aligned with the calibration line located on the 2nd or 3rd tooth from the center. Some of the older AccuGreen 3000 Drop Spreader spreader models do not have a raised ridge. On these spreaders, line the front edge of the shut off bar to the calibration line.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and raised ridge or front edge of the shut-off bar meet. If you have any difficulty checking or adjusting the calibration, contact us and we will be happy to help walk you through the adjustment.
Again, thank you for taking the time to contact us and for your interest in Scotts. Please feel free to call us at 1(800)5438873 anytime we may be of assistance.
Mar 03, 2011 | Scotts Company Scotts& Accugreeen 3000...
Need the setting for a Scotts Pro edgeguard broadcast spreader for pre-emergent
Hi, W/D here.
The spreader setting instructions will be found on the back of the bag, and you will set your spreader gate opening accordingly.
Best regards, --W/D--
Feb 18, 2011 | Scotts Company Scotts Pro Edgeguard...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Aug 09, 2009 | RTO Accugreen 1000 Drop Spreader
Flow control lever doesn't open hopper door
your fertilizer is got clumps in it. I have experienced the same when using TSC fertilizer (cheap and wet).
Mar 22, 2009 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
Garden Logo
592 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
