Question about Garden
I need the lever that controls the opening of the feed gate
The only number I can find is 0195. No explanation as to what this no. is
2 Suggested Answers
  • 44530 Answers
SOURCE: I need the lever that controls the opening of the feed gate. The only number on the spreader is 0195 ther is no explanation for this number
I would take the machine to a lawn mower shop and get advice as to what make it is and if there are any generic levers that could be adapted to do the job.
Posted on Apr 08, 2015
How do I REPLACE SHIFT CABLE
rtm? no symptoms so i must guess, ill say , cant shift. and is not park lock out causing that.
want to read the manual or me to you.'?
ill guess you.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click 1996 to 2001
it replaces like all cables do
detach both ends and remove it. if clamps seen those too.
what matters is adjustment is needed.
some have 2 cables, one to gear box and one to ignition switch.
Chapter 21, page 150 states
REMOVAL
(1) Shift transmission into Park.
(2) Remove shift lever bezel and necessary console
parts for access to shift lever assembly.
(3) Disconnect cable at shift lever and feed cable
through dash panel opening to underside of vehicle.
(4) Raise vehicle.
(5) Disengage cable eyelet at transmission shift
lever and pull cable adjuster out of mounting
bracket. Then remove old cable from vehicle.
INSTALLATION
(1) Route cable through hole in dash panel. Fully
seat cable grommet into dash panel.
(2) Place the auto transmission manual shift control
lever in "Park" detent (rearmost) position and
rotate prop shaft to ensure transmission is in park.
(3) Connect shift cable to shifter mechanism by
snapping cable retaining ears into shifter bracket
and press cable end fitting onto lever ball stud.
(4) Place the floor shifter lever in park position.
Ensure that the pawl is seated within the confines of
the adjustment gauge clip.
(5) Snap the cable into the transmission bracket so
the retaining ears are engaged and connect cable end
fitting onto the manual control lever ball stud.
(6) Lock shift cable into position by pushing
upward on the adjusting lock button.
(7) Remove and discard the shift cable adjustment
gauge clip from the park gate of the shifter.
easy?
Aug 25, 2015 | 1996 Jeep Cherokee
Apr 07, 2015 | Garden
I want to retrofit my moultrie atv spreader manual feed gate with an electric feed gate. They did not offer the electric feed gate when I purchased my current model. Both models are identical except for...
I am also looking to retro fit my manual gate spreader with the electric gate. I emailed Moultrie with the question about it and they emailed back about two weeks later that I needed to contact customer support. I call customer support but hung up after being on hold for 15 minutes. I have not found the electric gate anywhere else so I guess I will have to call them back. At this point it appears that is the only way to get one. I have been told the retro fit works with no problem.
Moultrie Customer service: 1-800-653-3334
Jan 14, 2013 | Moultrie ATV Spreader With Electric...
Ice maker will only dispence cubes, no crushed
I had this problem on a differnt fridge. What I discovered is that the tray has a spring that pushes the ice grinder into a postition by default. When you remove the ice tray, depending on whether the maker was set for crush or cube, the spring arm may reset to the undesired position. To fix it, I set the control on the fridge to match what was always coming out. Then I pulled out the ice drawer. Then I reinserted it and it lined up better with the interior controls. I ran some ice through it. Then after the ice matched the setting, I tried the other setting (cube or crushed). It was fixed..Hope this helps.
Aug 22, 2012 | Frigidaire Refrigerators
How do i repair shifting cable from cosole to trans.?
Welcome to FixYa.com
REMOVAL
1. Remove air cleaner and air intake hose assembly.
2. Remove center dash trim panel.
3. Remove center console cup holder assembly.
4. Remove floor console assembly.
5. Remove console side panels.
6. Remove Transmission Control Module ftMJ bracket.
1. Remove TCM.
8. Remove shifter cable from transaxle operating lever by removing nut and clip.
9. Remove shifter cable from shifter lever assembly by removing clip.
10. Remove shifter cable from shifter lever mechanism.
11. Remove cable from firewall grommet by removing grommet assembly nuts.
12. Remove gearshift cable from vehicle.
ADJUSTMENT
Lift and rotate the gearshift hand lever into the park (F9 gate position and remove the ignition
key. This confirms the shift lever is in the gated park (F9 position.
After confirming the park gate position. turn the ignition switch . If the starter will operate. the
park gate position is correct. Move the shift lever into the neutral (NJ position. If the starter
will operate in this position, the linkage is properly adjusted. If the starter fails to operate in
either position, linkage adjustment is required.
1. Park the vehicle on level ground and set the parking brake.
2. Place the gearshift lever in park (F9 gate position and remove key.
3. Loosen the cable adjustment screw at the transaxle operating lever.
4. Pull the transaxle operating lever fully forward to the park detent position.
5. Release the park brake, then rock the vehicle to assure it is in park lock. Reset the park
brake.
6. Tighten the cable adjustment screw to 8 Nm (10 inch Ibs.J. Gearshift cable should now be
properly adjusted.
1. Check adjustment by usinq the precedinq procedure.
Thank you for Using FixYa.com
Kind Regards, Lee
Your Master Technician FixYa Expert
Jan 31, 2011 | 1997 Chrysler Sebring
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
The rear hatch seem to be jammed or stuck it wont open at all how can i get it open
Crawl thru the front to the rear of the truck, Remove the two screws on the gate release handle (they are underneath the handle, two philips).
Gently pull on the plastic panel by the release handle, it will come out about 4 inches, it should be enough if you have a small arm (which I have.) I wedged a plastic 20oz bottle between the rear gate and the inner plastic panel, to keep the plastic held out, don't over stress the plastic it will break if its old enough, look down from the window hatch about 5 inches or so and notice the 2" x 3" opening, there is a lever in there that is moved by the actuator, and a piece of plastic (which is what my friends truck needs, if someone has a part number or aftermarket please advise) but if you reach in to that access panel, there is a slide that moves from right (looking at the gate from the inside) to left, moving it to the left (Opens the window)
Apon opening the window, remove the plastic bottle, and open the rear gate hatch, when the hatch is open there are two screws one on the left side of the gate, and on the right side.I hope this helps you out, remember: don't overstress the plastic, strip out the screws, or break the window..
Once you have everything out, you can replace the actuator or fix the wire leads that may have come loose form the rear door actuator keep you from opening the rear window.
Good luck and thank you for using fixya
Mar 06, 2010 | 2001 Chevrolet Blazer
It seems that I have a short in my wires. My tail lights wont stay on. My problem is the lift gate is stuck and I cannot access the lights. When u use the remote to open the doors it makes a funny sound....
You should be able to remove the trimpanel on the lift-gate. then at the location of the striker in the middle-bottom of lift-gate you should be able to access a rod. Grab the rod with pliers, if pliers won,t fit the rod connects to a metal lever attached to the striker assembly, pry the lever away from the striker and this should release you gate....Good Luck!!!
Oct 15, 2009 | 1999 Jeep Grand Cherokee
Trunk lid on 2005 sequioa wont open. I can hear it click to indicate it is unlucked when I use the fob or the key.However, when I press on the latch/handle to pull it open, nothing happens. It stays stuck....
The trunk release handle is made out of plastic, there is a lever that contacts the release lever inside, the lever part on the handle breaks off. Use a flashlight and look inside
the small square opening you will see the release lever which metal. use a screwdriver to push this lever down, the rear gate will pop open (be sure it's in the unlocked position) after the gate is open remove the inside paneling to get to the mounting nuts/bolts for the plastic handle.
It's a good idea to get the new one first so you know what you're dealing with.
Oct 27, 2017 | 2004 Toyota Sequoia
Tailgate will not open
you need to remove the tail gate rear cover (i think it is a torx bit 30) and then manualy open the tail gate. more than likely it will need a handle, and two latches.
Jul 12, 2008 | 2000 Ford F150 Flareside SuperCab
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
