Question about GE Refrigerators
Ice building up in freezer
Model no. gts22jcpbrww
    Top Expert:
  • GE Master
  • 12,962 Answers
Until you find the problem you can use unit by unplugging it, melting the ice build up, and re plugging - will work until the ice builds up again and insulates the evaporator.
Chances are that the defrosting element is open and needs to be replaced.
Posted on Apr 08, 2015
  • GE Master
  • 2,963 Answers
Probably the defrost timer or the defrost heating element that said timer supplies are bad. One of the several online appliance parts stores have been helpful to me.
Ice build-up in freezer
This is normal for this model. It is operating as it should.They are not a true frost free model
Mar 12, 2012 | Amana Refrigerators
Model No IK 458 -4-4T; Product No 925 780 652 02 Ser No 14100010. I get ice build-up on floor of fast freezer comp which jams pull-out basket.
If the defroster coil is not working, then ice will build up on the coils inside the back of the refrigerator.
But, you're saying that it's accumulating on the floor of the freezer jamming the pull out basket.
I would say that the timer or overflow valve is bad on this refrigerator causing ice to build up on the floor of the fast freezer compartment causing the jamming.
Jul 19, 2010 | Freezers
Door jam icing up
door has to seal tight. also, there are door frame heaters called, "Anti Sweat Heaters." It is to prevent condensation and ice build up around the doors. Have that checked out.
May 24, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice build up in freezer...Auto Defrost not working Model unknown...smaller model...about 5 feet tall...2 feet wide...freezer on top..no ice maker. Bought in 2002....noise during defrost quit about 2 months...
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from repairclinic.com
Jan 31, 2010 | Roper Refrigerators
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
