Question about Humax Televison & Video
Hi there I have a humax lu20-td2 won't scan for channels
    New Friend:
    Problem Solver:
  • 9 Answers
If it wont scan anything, you possibly have a broken tuner. On some models you can change the tuner yourself , on others you will need to send back the unit for repair.
If its build in then forget about the " diy" repair, however if you see 2 screws (each one on the left and right side of the cable input) you can take the faulty tuner out, and replace it with a new one.
Posted on Oct 26, 2016
2 Suggested Answers
  • 74 Answers
SOURCE: Humax lu23 td2 cannot retune it say menu not avaliable when i press the menu button
Is tv being used in the av modes if so tuning menu will not show. Possible cause could be external units like dvd player are taking control . Unplug all external unit and try menu again
Regards Derrick
Posted on May 13, 2012
What does code 576p indicate?
576p means 576 lines, progressive scan. 576 is number of visible lines on the UK system (and other nominally 625 line countries). The normal transmission system for these countries is 576i (interlaced scan), so I suspect that you are only seeing the 576p indication because there are no channels, and your TV is interpreting this as progressive scan.
The reason for no channels may be a poor signal from the aerial, or that the device (Humax or TV) has not been tuned. If you have power-saving enabled on the Humax, it will not pass on the aerial signal to the TV when the Humax is in standby. If this is the case, either turn power-saving off, or use a splitter to feed the aerial separately to the TV and Humax.
Oct 20, 2015 | Humax PVR9300T HD DVR
How do i unlock Humax LU23-TD2 TV
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.
Visit the associated blogsites too.
Sep 21, 2014 | Humax Televison & Video
Setup humax lu23 td2
have you tried plugging other any other components to the ports to see if it does the same thing
Dec 01, 2013 | Televison & Video
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
Humax 20" lu20-td2 tv just flickers use to flicker then come on now just flickers thank ernie
needs new capacitors if you look on mainboard it is 31 32 33 just fixed 2 with same problem
Aug 27, 2010 | Humax LD2060 20 in. EDTV-Ready LCD...
Humax 8000T not used for a while, now says ''no or bad signal'' and says no channels available when it searches.I tried resetting to default settings but still no joy. When I checked signal status it says...
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
Oct 24, 2009 | Humax Televison & Video
1 - The correct sequence for  all channel data input: a.satellite name; b.frequency; c.polarisation; rate; e.fec. Did you respected that for every single one?
2 - If yes then is the signal strength for each frequency above 80% ?
3 - Did you scanned all satellites after you have loaded the data?
Oct 04, 2009 | Humax Televison & Video
Same problem Humax LU20/TD2 TV; Virgin remote
Apr 13, 2008 | Televison & Video
Televison & Video Logo
192 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
