Question about GE Refrigerators
My ge mnogram mic. Work fine but aftre a a few minetsminets it gets stuk on auto defrost and nothing works .if i onpug and puget again it will work agien but aftre a few minets it wil get stuk agien.
    Top Expert:
  • GE Master
  • 52,135 Answers
Go back to school and learn how to spell .
Posted on Apr 07, 2015
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Posted on Mar 17, 2009
aasc
  • 1606 Answers
SOURCE: GE Side by Side Freezer Side Not Defrosting
You have a bad element .
Posted on Jul 18, 2009
dmftrucker
  • 1922 Answers
SOURCE: My Ge monogram side by side refrigerator is about
could be the defrost sensor or timer circuit that is malfunctioning or a combination of both parts
Posted on Oct 28, 2009
Testimonial: "Thanks for the feedback. I agree with you!"
Upper fridge won't go below 50 degrees,but freeze section is freezing things to hard...do not hear the fan running.....ice behind panel in fridge....
Auto defrost mechanism is not working . Check defrost heater element, defrost timer, defrost thermostat for operation.
In meantime defrost unit completely and it will work fine for a few days till it freezes up again. Probable open heater element.
Nov 20, 2015 | Refrigerators
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
Mar 31, 2014 | Avanti FFBM921PS 9.2 cu. ft. Bottom...
GE Profile pss27sgrss has a bad main pc board
Yes I would agree that you get another refrigerator! The GE PSS27SGRSS is an Artic/Profile model and people have had nothing but complaints about the motherboard problems. I recommend you buy something that has no motherboard or electronic defrost. The best refrigerators out there are ones that have the simple defrost timer and no electronics, Thanks Sea Breeze
Dec 05, 2012 | GE PSS27SGRSS Side by Side Refrigerator
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Sudenly stops working everything in freezer thaws out and refridgerator goes warm,the lighhts are on and the fan inside the freezer is blowing warm air.if i unplug it and it sits for a few hours and then i...
The auto timer in your Fridge is faultly and is not defrosting in the eight hour cycle. There could also be any wire detached from corrosion inside/within the freezer compartment that gives wrong signals to the the thermostat. You will have to remove the inside cover to confirm.check the wires to the heater/ failure of the heater. In case you are not able to do the work have this in mind and look into what the technician responds. take an estimate and move on.Helpful? good day
Jul 02, 2010 | GE GSH25JFR Side by Side Refrigerator
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Mic is not recognized
i have a GE 98980 headset and window vista wont reconize the mic but the headphones work fine. How do i get the mic to work?
Jun 02, 2009 | GE (98980) Headset
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side regrigerator
You'll find that the defrost heater is the problem most of the time.
Dec 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
