Question about Mitsubishi WD-73C9 73" DLP TV
How do I fix my WD-73C9 after an attempted 11.03 update broke my tv
I bought this tv with it needing a new dmd chip, a couple months after that replacement the lamp went out. With the new lamp and dmd chip the tv worked great, except for a couple bugs with the inputs. I have some aspects of my OCD I haven't been able to kick and the organization of the inputs on my living room tv is one of them. There were duplicates of the input devices and they didn't match what I had hooked up and I couldn't change them so I figured hey, there's an 11.03 update. Maybe that's what it needs. Nope, it bricked my tv. I performed the format and the unzip correctly, I waited for the tv to fully power down and I've repeated the 3rd through 5th step I don't know how many times. The green light blinks green with the blue welcome screen and it does not shut itself down. DIY trouble code shows no failure. Yahdayah. All I can find is that it's more than likely the main board. My primary question is, how do I undo whatever I did. If the answer is I can't then my next question is, how could the update have ruined the main board in this tv.
    Scholar:
  • 85 Answers
Corrupt or wrong firmware will make the board seem bad to diagnostics. Do you have or can you get a copy of the old version firmware? If so I'd try to restore it. You also might try re-downloading the update (after triple-checking that you selected the right model.)
Beyond that there's a chance (albeit unlikely) that tech support might be of some value, specifically I'd ask if they've had many reports of problems with the latest firmware upgrade, and I'd insist they provide me with a copy of the old version -- even if it's not on their web site you know they still have it.
Since the update facility is still apparently operable all may not be lost, it all hinges on obtaining firmware that's valid for the hardware.
(Note that It's possible that a portion of the flash memory has failed and can't be rewritten, in which you are likely screwed.)
Posted on Apr 08, 2015
Installed dmd chip for a mitsubishi wd-60c9 DLP and got the 66 error code instead of fixing the white dot issue
Hello. I have done a lot of DMD chip replacements. I don't have access to the service manual at the moment, but the only thing that could cause an error code is to leave something disconnected. Did you check the color wheel connections on the lens side of the DMD board? The flat cable and the power connector might cause that error code. Good luck!
May 16, 2016 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
What is a dmd on a mitsubishi 73" tv
Howdy Mike-d. here,
I do not know what a DMD is on a Mitsubishi 73'' TV.
I did do a little web searching and here is a couple of things I came across.
From this website: http://www.tvserviceparts.com/Mitsubishi_DMDChips.html WD73833 ALL 4719-001997 DMD Chip, DLP, 1920X1080/XHD5, 0.65"/ DC4, TYPE X NON
I have no ties to these websites.
"I researched this and it was a DMD chip that needed to be replaced."
from this website: http://www.consumeraffairs.com/home_electronics/mitsubishi.html
Hope that helps.
Mike-d. out
mikedee4@gmail.com
Mitsubishi TVs and Electronics Mitsubishi TV DMD DLP Chip
Jun 27, 2014 | Mitsubishi WD-73833 73" HDTV
TV wont turn on flashing red light
Which light flashes red on the set? Please respond to this same post for assistance.
Feb 11, 2013 | Mitsubishi WD-73C9 73" DLP TV
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
Hi my 73inch DLP is showing snow screen :(
You need to replace the DLP chip. Get a quote form a TV repair shop.
May 20, 2011 | Mitsubishi WD-73C9 73" DLP TV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-73C9 73" DLP TV Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
