Question about Garden
I need the lever that controls the opening and closing of the feeder gate
2 Suggested Answers
  • 253 Answers
SOURCE: gate light on even when gate is closed
Open gate and find where the wiring enters the gate (bottom of door) pull back the rubber insulator and check for broken wires or wires touching each other.
Posted on Mar 05, 2013
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
Centurion gate motor
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
Myhouse gate
There is a switch in the housing that tells the controller if the gate is open or closed. The switch is bad or out of adjustment.
Aug 21, 2013 | Home Security
Ice maker will only dispence cubes, no crushed
I had this problem on a differnt fridge. What I discovered is that the tray has a spring that pushes the ice grinder into a postition by default. When you remove the ice tray, depending on whether the maker was set for crush or cube, the spring arm may reset to the undesired position. To fix it, I set the control on the fridge to match what was always coming out. Then I pulled out the ice drawer. Then I reinserted it and it lined up better with the interior controls. I ran some ice through it. Then after the ice matched the setting, I tried the other setting (cube or crushed). It was fixed..Hope this helps.
Aug 22, 2012 | Frigidaire Refrigerators
How do I install the remote control
a remote control chain link gate is a common site in rural parts of the country, although the popularity is growing in more suburban neighborhoods, too. Remote control gates serve two main purposes. The first purpose is security. A closed gate is one obstacle to keep intruders and burglars off of your property. The second purpose is convenience. A remote control gate does not require you to get out of the car to open or close the gate. In rural areas, the gates also function to keep pets and livestock from wandering off your property
ceiling lights
Dec 24, 2011 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
I understand your frustration. Try this solution.
* Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
* Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
Close the scanner cover.
Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
* Turn the power back on.
I hope this helps you.
Aug 03, 2010 | Brother DCP 1000 All-In-One Laser Printer
The first slide advanced and then a black piece came across the lens and didn't retract. what do we do?
These projectors are equipped with a "dark shutter", which stays closed unless it detects a slide in the "gate" (projection path). With the projector on, try GENTLY inserting a pencil on the movable levers that hold the slide vertical in the gate. If the "dark shutter" does not open, then chances are the lever that "trips" it open has been bent or somehow moved out of position.
I recommend you contact a factory-trained repair dealer.
Nov 15, 2009 | Kodak Carousel 4400 Slide Projector
When I open my rear gate the done and interior lights stay on when the gate is closed. I have to pull the fuse. If I drive around and put the fuse back in the lights stay off till I open the gate again and...
Hello, it sounds likethe switch that controles the light is jaming, try pushing the sswith in and out firmly with your finger. If you get the same responce as you do when uou close the tail gate you have found the problem. The switch may need replacing.
Nov 05, 2009 | 2000 Jeep Grand Cherokee
Ricoh Aficio 1035 ARDF is not duplexing, why?
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
Zebra 140xi II error
If you open the case there is a sensor that detects whether the head is opened or not that is connected to the open and close lever. Sometimes the tab that blocks the sensor when it is closed get out of alignment or comes loose or the sensor is jarred loose. Make sure the tab breaks the beam.
Jan 31, 2008 | Zebra Printer 140-751-00000
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
