Question about Martin Yale 1217A Medium-Duty Auto Paper Document Letter Folder, Up to 10,300 8 1/2 X 11 sheets per hour, Paper Weight Range 18-90 bond 1217 A 1217-A 1217 AutoFolder
Can't get tri-fold to work on 1217A auto folder
Setting for tri fold but only does first fold
Auto focus mirror is not folding up completely.
I do not understand your question?
Do you mean that when you set the lens to 18mm, the lens is not folded completely? That is the normal behviour. The lens that comes with the kit 18-55mm, folds completely at 35mm more or less.
Feb 27, 2015 | Canon EOS 1200D Black SLR Digital Camera...
What are the different types of folds that a paper folding machine can do?
There a few different types of folds that a paper folder can do. All the different kinds of folds can be found on this site. Before you get excited about all the different folding options that are available you want to make sure that your folding machine is capable of doing those folds.
Sep 24, 2013 | Office Equipment & Supplies
What are the benefits of an automatic paper folder?
These are great because you can choose what type of fold you want. You can choose between all different folds on the control panel. Lots of folding typesare already programmed into the machine. These machines are very efficient and can fold 18000 letters/hour.
Jan 17, 2013 | Office Equipment & Supplies
I wrote the long message and wanted to send it later. Later I could not find my written mesage to send email. I did not find outbox nor Draft symbol in the screen. How should I get my written message back
It should have been auto saved in the drafts folder. If it is not in the drafts folder, It is most likely gone. Outlook uses word as an editor and word will auto save every so often. It will place an .asd file in your temp folder. Your temp folder location will depend on your Windows version. I'm not talking about windows/temp. It is most likely under Documents and Settings\(your user name)\Local Settings\temp. The Local Settings folder is hidden so you must set your settings so that you can view hidden files and folders.
I suggest either making sure you save your message to draft every so often as you write it .. OR a better solution is to use Word. Word will auto save every so often and the document can be recovered.
How auto save works
How to view your Local Settings files/folders
hopefully you can find the saved file there.
Feb 26, 2010 | Microsoft Office Outlook 2007: Windows
Thechko LF286 letter paper folder not working
Motor burned out.. commn fault in this model I got mine eventually from China after googling its part number.
Jun 05, 2009 | Sharp Office Equipment & Supplies
Paper folder grabs too many sheets and doesn't fold accurately
Not sure what make / model you have but folders are pretty much the same. The issue with the paper feed is your retarder, also known as the paper seperator. On the feed table where you load paper there should be a pad or rubber wheel. Look for an adjustment screw. You need to close the gap enough so that it only takes one sheet at a time. The extra fold sounds like you need to adjust the fold plate stop positions just a hair. If you give me the make and model I should be able to email you a manual.
Apr 10, 2009 | Office Equipment & Supplies
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Martin Yale 1217A Medium-Duty Auto Paper Document Letter Folder, Up to 10,300 8 1/2 X 11 sheets per hour, Paper Weight Range 18-90 bond 1217 A 1217-A 1217 AutoFolder Logo
380 people viewed this question
Top Martin Yale Office Equipment & Supplies Experts
gbob59
1Teddybear
1Teddybear
Tom Chichester
Are you a Martin Yale Office Equipment and Supply Expert? Answer questions, earn points and help others
