Question about ASUS Tablets & eReaders
My tablet will not charge
When I do get it to charge I cannot move it or it will stop charging
    Habit-Forming:
  • 82 Answers
This is the main misstake all they do... we mustn`t move it when charging.... looks like dc jack has broken and needs repair.
Posted on Apr 07, 2015
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
Tablet won't charge
Check your charging pin. Is it loose? Is it moving or pushed backwards. The charging pins on most of the less expensive tablets are malfunctioning. 4 tablets I've recieved had terrible problem that way. Mostly unfixable, unless that's the problem and you know how the solder such things. Also try a new micro usb and a different electrical outlet, good luck!
Mar 04, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
My visual land android tablet wont charge it started to charge then jst stopped
If it just stopped charging and you have tried other chrgers, then the probable cause would be the battery for the tablet has failed. This is fairly common and would require disassembly of the tablet and replacement of the battery to fix.
Feb 15, 2015 | Visual Land Prestige 7L Android 4.1 Jelly...
Battery won't charge, what do I do
More history would help narrow the possibilities, but I'll assume you have had it for a while and have recently found it stopped charging. 3 most common culprits, assuming it will not charge at all: cable, charger, and charging port. If it's the last, buy a new tablet, but not before trying a GOOD quality cable and a charger that is known to work (i.e., it charges something similar). First, look very closely at the charging port, for damage, dirt, dead spiders, missing pieces, etc. If clean and straight, move on to debugging the cable and/or charger. Cheap debugging means borrowing a known good cable and charger from a friend. Not from a stranger. That tends to involve the police and mugshots, and can ruin political aspirations. Replace one thing at a time (cable first), and pay careful attention to getting a good connection. Try every combination, and be patient. If it is the cable, seriously consider getting a higher quality cable. Cheap cables are a huge problem, and can contribute to damaged charging ports. Good luck!
Jul 17, 2014 | Visual Land Prestige 7 Internet Tablet...
Battery will not charge
it means that something is wrong with your battery or its charger
Feb 02, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Nov 09, 2013 | Tablets & eReaders
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Le pan tablet wont charge how to reset
Le pan tablet not charging after all night does not show battery when plugged in.tablet does turn on battery level about 30%?
Apr 28, 2012 | Tablets & eReaders
Tablets & eReaders Logo
60 people viewed this question
Top ASUS Tablets & eReaders Experts
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
